Question about Kenmore 43142 Front Load Washer
417.29042991 door switch
How to remove switch assembly
  • tinades33 Dec 26, 2008
    does any one have the schematics for model 41729042991?
    President:
  • 1,314 Answers
If i reamber right you can take the bottom off reach up after un plugging unit of course rebove the screws at the door and get it that way if not take the two trox screws out of the top panel slide it slightly back remove it and get at it that way
Posted on Dec 31, 2007
Replacing turn signal switch on 1993 chevy astro
To Remove:
  1. Disable the SIR system. (See section on SIR Precautions)
  2. Remove the steering wheel from the steering column. (See section on Steering Wheel)
  3. Remove the steering column trim covers.
  4. Remove the wire harness straps from the wire harness assembly.
  5. Disconnect the multifunction switch/SIR coil assembly connector from the base of the column.
  6. Remove the multifunction switch/SIR coil assembly lead from the wire harness assembly.
  7. Remove the 3 pan head tapping screws from the multifunction switch/SIR coil assembly.
  8. Slide the multifunction switch/SIR coil assembly off of the steering column.
Hope this helps. Be very careful where airbag is involved.
Apr 08, 2018 | Chevrolet Astro Cars & Trucks
I am trying to remove ignition cylinder. I have pressed release button on the back, but the cylinder will only come halfway out.
TO REMOVE IGNITION SWITCH LOCK CYLINDER ASSEMBLY (w/o Smart Key System)
(a) T urn the ignition switch lock cylinder assembly to the
ACC position.
(b) Insert a screwdriver into the hole of the steering column upper with switch bracket assembly. Pull the ignition switch lock cylinder assembly until its claw contacts the stopper of the steering column upper with switch bracket assembly.
(c ) Insert a screwdriver into the hole of the steering column
upper with switch bracket assembly. Tilt the screwdriver
to disengage the claw of the ignition switch lock cylinder assembly, and pull out the ignition switch lock cylinder assembly.
25656969-ts5vql1j3jwqenesgxdwpnsg-5-0.png Thank you for visiting Fixya.
Apr 20, 2015 | 2010 Toyota Corolla
How to remove the ignition lock cylinder from a 93 geo storm
is the lock assembly in the car or out?
there are 2 jobs here, removing the assembly
and after that, attacking the lock it self.???????
any lock smith can rebuild the lock, proper
it has pins that are pressed out.
it can even be rekeyed.
the remove assembly is covered in the FSM, no books?
alldata.com covers that.
it really is an Isuzu. impulse.
my guess is its job 1, assembly out.
so toss coin lands on job1
(on most cars, steering wheel must be removed)
once that is done, its obvious from there, right? that clamp there with the antitamper screws? then must be removed. and replaced new..
a rare car , and even more one that runs....
here is the online FSM answer
  1. Remove the negative battery cable.
  2. Remove the steering wheel.
  3. Remove the combination switch assembly.
  4. Turn the key to the OFFposition, depress the retaining pin and remove the ignition lock cylinder from the switch.
  5. Disconnect the electrical connector from the ignition switch.
  6. Remove the snapring and spacer collar from the steering shaft.
  7. Disconnect the back drive cable from the ignition switch.
  8. Remove the ignition switch bolts and the ignition switch from the steering column.
now back in?
  1. Install the ignition switch to the steering column and tighten the bolts.
  2. Connect the back drive cable to the ignition switch.
  3. Install the spacer collar and the snapring to the steering shaft.
  4. Connect the electrical connector to the ignition switch.
  5. Install the lock cylinder into the switch.
  6. Install the turn signal switch screws and the turn signal switch.
  7. Install the four screws and the coil assembly to the turn signal switch.
  8. Connect the coil assembly wiring harness to the turn signal switch.
  9. Install the two piece steering column cover and the two piece steering column cover screws.
  10. Raise the steering column and install the upper steering column mounting bolts. Tighten the bolts to 18 ft. lbs. (24 Nm).
  11. Install the left lower dash trim panel and tighten the lower dash trim panel screws.
  12. Install the lap air deflector and tighten the lap air deflector screws.
  13. Install the knee pad assembly and tighten the five screws, the bolt and the nut attaching the assembly.
  14. Install the engine hood opener cable.
  15. Install the engine hood opener and tighten the two screws.
  16. Connect the electrical connector to the cigar lighter bezel and install the bezel.
  17. Connect the electrical connector to the left switch bezel and install the bezel.
  18. Install the steering wheel.
  19. Connect the negative battery terminal to the battery.
that?
Oct 08, 2014 | 1993 Geo Storm
Replace ignotion switch on 95 geo trackker
1.Remove steering wheel cover from screws in bottom
2. pop off horn cover should snap off
3. Unplug three plugs to switch assembly
4. Remove steering wheel nut pull steering wheel may need puller
5. unbolt switch assembly from ignition bracket about three bolts
6. remove switch assembly and lay to side
7. mark ignition bracket vertically and horizontally
9. remove two tamper proof bolts with chizel
10. unplug ignition switch and remove to bolts from rear of ignition switch and remove switch. installation is reverse of removal.
Jun 08, 2014 | 1992 Geo Tracker
Heater switch replacment
Hello! it's my job to make things as easy for the customer as possible...Therefore I must ask why you want to replace the heater switch? Is it because you have lost one or two of the switch speeds? Your vehicle is noted for loss of the Blower Motor Resistor...
Changing the Heater switch means removal of the Climate Control Assembly which is not the easiest of jobs...I've included the process...But are you sure the blower resistor is OK? If you have lost 1,2, or all blower motor speeds it's more than likely the Resistor pack. And a lot easier to change...
Guru...saailer
Remove climate control:
  1. Remove the instrument cluster finish panel...
  1. Remove the 3 climate control assembly screws...
  1. Disconnect the climate control assembly vacuum connector...
  1. Disconnect the 5 climate control assembly electrical connectors...
  1. Remove the climate control assembly..
Removal of blower motor Switch:
  1. Remove the blower motor switch knob.
  1. Remove the blower motor switch.
    1. Remove the screw.
Removal of blower motor Resistor:
Blower Resistor is under the battery tray...
MOTORCRAFT Part # YH1698 ...cost $25
Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Dec 22, 2011 | 2007 Ford Econoline
Error code 41
The error code E41 means the control board is detecting an open door switch. It might be due to a broken wire harness, broken door lock/switch assembly, or in worst cases a faulty control board.
Unplug the machine or disconnect power. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the spring of the retaining hoop then remove it.
Carefully peel off the part of the door seal from the lip of the door opening near the door lock/switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock/switch assembly
to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock/switch assembly out of the front panel then
disconnect the door switch harness then short circuit the terminals by putting a jumper wire between them.
Put the door lock/switch assembly back into position in the front panel then secure it with the securing screws previously removed.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop. Reconnect power and run a test cycle. Replace the door lock and switch assembly (part #131763202) to address the problem if the washer works fine with the door switch bypassed. If not, replace the control board.
Jul 18, 2011 | Frigidaire ATF6700FS Front Load Washer
Need to remove the door panel and replace motor
This is the best I got hope it helps!
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove the door speaker.
  3. Temporarily reconnect the power window switch to the door harness.
  4. Operate the power window switch to raise/lower the door glass until the door glass bolts can be seen.
  5. Remove the door glass bolts.
  6. Raise the door glass up into the door frame/channel and hold in place with a suitable tool.
  7. Remove the module assembly bolts and the module assembly.
  8. Disconnect the harness connector for the module assembly, and disconnect the harness clip from the back.
  9. To install, reverse removal procedure.
Rear
  2. Remove the rear door finisher.
  3. Remove the plastic vapor barrier, being careful not to tear/damage it.
  4. Temporarily reconnect the power window switch to the door harness.
  5. Operate the power window switch to raise/lower the door glass until the bolts can be seen.
  6. Remove the door glass bolts.
  7. Raise the door glass up into the door frame/channel and hold in place with a suitable tool.
  8. Remove the bolts and the regulator and guide channel from the panel.
  9. Disconnect the connector and remove the regulator assembly.
  10. To install, reverse removal procedure.
Jan 12, 2011 | 2004 Nissan Altima
The left rear door window fell off the track. How do I remove the door panel to access it.
This is the complete procedure you stop when you see the problem.
1. REMOVE REAR DOOR INSIDE HANDLE BEZEL
(a) Remove the screw.
(b) Using a screwdriver with its tip taped, disengage the 2 claws A.
(c) Pull out the the rear door inside handle bezel in the direction indicated by the arrow, disengage the claw B, and remove the rear door inside handle bezel.
2. REMOVE DOOR PULL HANDLE
(a) Using a screwdriver wrapped with the protective tape, disengage the 2 clips and remove the door pull handle.
3. REMOVE REAR DOOR TRIM BOARD SUB-ASSEMBLY
(b) Disengage the 7 clips.
(c) Disconnect the connector and pull up on the rear door trim board sub-assembly to remove it.
4. REMOVE REAR DOOR INSIDE HANDLE SUB-ASSEMBLY
(a) Remove the bolt.
(b) Disengage the 2 claws and separate the rear door inside handle sub-assembly.
(c) Disconnect the 2 cables and remove the rear door inside handle sub-assembly.
5. REMOVE REAR SPEAKER
6. REMOVE REAR DOOR SERVICE HOLE COVER
(a) Disconnect each connector and remove the rear door service hole cover.
HINT:
Remove the remaining tape on the door side.
7. REMOVE REAR DOOR GLASS RUN
(a) Connect the window regulator switch assembly.
(b) Fully lower the door glass.
(c) Remove the rear door glass run.
8. REMOVE REAR DOOR WINDOW DIVISION BAR SUB-ASSEMBLY
(a) Remove the 2 bolts, the screw and rear door window division bar sub-assembly.
9. REMOVE REAR DOOR QUARTER WINDOW GLASS
(a) Pull out the direction indicated by the arrow, remove the rear door quarter window glass and rear door quarter window weatherstrip as a unit.
10. REMOVE REAR DOOR QUARTER WINDOW WEATHERSTRIP
11. REMOVE REAR DOOR GLASS SUB-ASSEMBLY
(a) Remove the rear door glass sub-assembly as shown in the illustration.
(b) Disconnect the window regulator switch assembly.
12. REMOVE REAR DOOR WINDOW REGULATOR SUB-ASSEMBLY
(a) Disconnect the connector.
(b) Loosen the temporary bolt.
NOTICE:
If the temporary bolt is removed, the rear door window regulator may fall and become deformed.
(c) Remove the 3 bolts and the rear door window regulator sub-assembly and the power window regulator motor assembly rear as a unit.
(d) Remove the temporary bolt from the regulator.
13. REMOVE POWER WINDOW REGULATOR MOTOR ASSEMBLY REAR
(a) Using a "torx" driver (T25), remove the 3 screws and power window regulator motor assembly rear.
14. REMOVE REAR DOOR LOCK ASSEMBLY
(b) Remove the bolt.
(c) Using a "torx" socket wrench (T30), remove the 3 screws.
(d) Slide the rear door lock assembly downward, pull out the link from the outside handle frame, and remove the rear door lock assembly and cables as a unit.
(e) Remove the door wire harness packing.
(a) Using a "torx" socket wrench (T30), loosen the screw.
(b) Disengage the 2 claws and remove the rear door outside handle cover.
(a) Disengage the 2 claws and remove the rear door outside handle pad rear.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/flavio_517b938f50183b92
Jan 03, 2011 | 2006 Toyota Highlander
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Machine flashes F then dl. What can we do?
There's a fault detected with the door lock and switch assembly. The door lock is not working or the door lock switch is not activated. This indicates that the door lock and switch assembly is malfunctioning and needs to be replaced to address the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Using needle nose pliers, start where the spring and wire are connected and pull the wire out of the groove of the door gasket.
Remove the three screws securing the door lock and switch assembly to the front panel.
Gently peel the part of the door gasket near the door lock and switch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock and switch assembly behind the front panel.
Slightly lift the door lock and switch assembly then pull it back off the front panel and out of the cabinet.
Transfer the wiring harnesses to the new door lock and switch assembly one at a time then install it in place behind the front panel. Secure the
door lock and switch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Install the retaining hoop with the spring positioned at the bottom of the door gasket.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 43142 Front Load Washer Logo
238 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
