Question about RCA D52W19 52" Rear Projection Television
Cant get into service mode
I was just wondering if anybody knows how to get into service mode. We tried to hold down menu, pushing power, pushing vol up button, and nothing is happening. It is an RCA D52w19 rear projector TV. Are TV picture is having an hourglass effect on the top and bottom, which is making the picture distorted. By some of my research they call it pincushion something. It was working fine. went to move it 5 feet and pluged it back in and that is when is started.
    Sergeant:
  • 308 Answers
It seems very likely that when you moved the TV, a solder connection became loose causing the problem that no amount of adjusting will bring back. You "may" be able to get the picture to jump back by jarring the set, but the problem will likely return shortly. I'm also thinking that if the problem stays like it is, that the open solder connection has also caused a component or two to fail, and that you will have to get a tech to properly diagnose it. While he's fixing the problem, you may want to have the mirror and lenses cleaned if they show dirt and dust accumulation. Of course, if the estimate is over $600, you may want to put that towards another brand of HDTV. Samsungs and Panasonics seem to hold out rather well in my past experience.
Posted on Dec 31, 2007
Grandson used pass word and forgot password, now I can't unlock tablet.
Try resetting it by holding down the power button for 10 seconds.that would shut it down. Restart then try logging in. Try to factory reset using the combination buttons as listed below
look for a tiny reset pinhole along the case it may reset the tablet too All RESETTING Ways Below Holding Down Certain Sequence of Keys or Buttons will put Most Tablets or Android Phones in Service mode to Factory Restore to New.
Hold Vol + & Power 20 sec
Hold Vol - & Power 20 sec
Hold Vol + - & Power 20 sec
Hold Home & Power 20 Sec
Hold Vol + & home & Power 20 sec
Hold vol - & home & power 20 sec
Hold Vol + - & Home & Power 20
Dec 12, 2014 | Tablets & eReaders
Tip
Service menu codes panasonic
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save.
PA25UP / PD25UP / PX25UP :
* Using the remote control:
* Press the {MENU} button.
* Set "Antenna A" to "Cable".
* Select "Timer" menu and set sleep timer to 30 min.
* Press {OK} twice to exit menus.
* Tune to channel 124.
* Press and hold {VOL -} button ON THE PLASMA TV.
"CHK" appears in on top-left corner followed by 5 letter/numbers
(which are the cumulative hours in hex numbers)
* While the "CHK" is displayed, press the {OK} and {VOL+} buttons
ON THE TV simultaneously to toggle between Modes:
?ƒ?¢?¢?€??¬?¢?'¬? Red "CHK" for Serviceman ?ƒ?¢?¢?€??¬?¢?'¬? Yellow "CHK" for Aging ?ƒ?¢?¢?€??¬?¢?'¬?
* Press the {POWER} button on the remote to select one of the six
Serviceman Adjustments Modes.
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
* Press {CH+} {CH -} on the remote to select the settings
on each of Service Adjustment Modes.
Write down the original values before modifying anything.
It's easy to erroneously adjust the wrong item.
* Press {VOL+} {VOL -} on the remote to change values.
* Press the {POWER} button on the TV to exit the service menu.
LCDs / CRTs / RPTVs :
* Hold down the {VOL -} button ON THE TV.
Model PT45LC12:
1. Press and hold Vol Dn on center panel and press recall button on remote until Work Mode is displayed on screen.
2. Press and hold Vol Dn on TV and Swap button button on remote until Factory Adjust is displayed on the screen
3. Use Channel Dn button to select Digital and press the Action button.
PROJECTORS :
* Go to "Options" menu.
* Highlight "OSD".
* Then press and hold the {ENTER} button,
until the Service Menu is displayed.
* Press the {MENU} button to exit.
on Apr 29, 2015 | Panasonic Televison & Video
Tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 | Televison & Video
I can't enter service menu on Sharp TV 60LE751
Give this a try...
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* Use {CH+} {CH -} buttons to navigate
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu
Mar 22, 2014 | Televison & Video
Ematic 7" QUAD CORE TABLET EGQ307 FORGOT PASSWORD HOW TO RESET IT CANT GET ON ANYTHING WITHOUT IT
I have also take help from this helpline number 1-888-551-2881..
before sometime i have also same problem like you, i forgot my password of my Gmail account and that account contain important data,,I just call this number 1-888-551-2881..& get best solutions
related website: Gmail Password Recovery
Jan 08, 2014 | Ematic Eb104 eBook Reader
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
Can't get into service mode.
invest in a service call,you tried .
Nov 04, 2007 | RCA 32F531T 32" TV
Toshiba 36inch color tv demo troubleshooting
Demo is activated / de-activated by holding a combination of
two buttons on the tv front for at least four seconds. Try menu &
power or vol up & chan up...........T.
Please rate this solution.......
Oct 28, 2007 | Toshiba 36A43 36" TV
Help please stuck in service menu
You should have purchaced the service manual before you went into the sevice mode, as the service mode is a dangerous place to be if you do not know anything about it. You can get the service manual from www.servicemanuals.net for about 20 bucks or so. A lot less expensive then a serviuce call I would think.
Aug 02, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Service menu
Have you tried replacing the EEPROM? It may have lost it's programming for that set. Stargazer
Apr 19, 2007 | Proscan PS36123 TV
RCA D52W19 52" Rear Projection Television Logo
128 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
