GE XL1800 1100 Watts Microwave Oven
Problem for GE XL1800 1100 Watts Microwave Oven
Turnable plate isn't working
By lizred2 on Oct 24, 2009
The turnable plate isn't working, I've already pushed the "turnable" button and nothing happens. Please help.
Solution #1
posted on Oct 24, 2009
Not Rated)
milten1
Rank: Guru  GE Kitchen Appliances  Expert
Rating: 90%, 495 votes
in order to be 100 % sure
you would have to check voltage to the motor while its suppposed to operate
take off the bottom 6 screws, you might need whats called a safe t, a torque wrench or star with a hole
most use phillips,
drop the bottom, you should see the turn table motor
disconnect the two leads and connect them to a voltmeter,,,
turn the unit on
you should read voltage to the meter
if not the problem is in your control board and will need to be replace
if you do read voltage and the motor is not turning
you will need to replace the actual motor
either way its a pretty simple repair and can be done without taking the unit dwon
Was this helpful?
Yes
No
Popular Solutions for GE XL1800 1100 Watts Microwave
Questions and Unsolved Problems for GE XL1800 1100 Watts Microwave
Do you recommend GE XL1800 1100 Watts Microwave Oven?
Answer
Answer
Our GE Space Saver XL1800 microwave only warms now. Everything else seems to work except the proper... (More)
Answer
no calienta pero fuciona es decir enciende pero no calienta
Answer
on startup the display shows " presionar clock " and leypad is locked
Answer
Doesn't heat food, and sounds much louder than normal. Any suggestions?
Answer
micro, fan on, light on, timer works, NO HEAT
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave... Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
