Model 106 9552882
freezer and fridg are not cooling, rotated defrost timer to make sure it is not stuck on defrost. both fans running, compressor is not starting, unit makes loud clicking noise every couple minutes. 12 years old, never any other problems.
If compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
heatman101
heatman101
relay was the problem, replaced and unit is working fine. figured it out for myself - thanks anyway...btw, unplugging the unit will not protect you from a charged capacitor!!!
Fridge is beeping intermittently even after hours of no beeping, and is not creating ice. which of the 3 backbuttons to control temp do i press.
how do i stop the beeping and gain ice control again?
Thanks for the great info. I found this too late but I'm nort sure I could have replaced myself anyway. The Maytag Performa Top Bottom fridge we have is only 6 years old and yesterday, the freezer items had frost all over them. And the fridge temp went up to around 50 degrees but the fans were running though. We heard a clicking sound on the bottom rear of the fridge but 10 seconds later, we heard the click again and that was it.
A guy came today and diagnosed it as the compressor starting unit after about 5 minutes. Then charged us 175 bucks, took about 8 minuted to fix the unit and went on his way.
