Question about Sony KV-32V65 TV
Sony trinitron KV32V65 color tv dual tuner purchased 1/09/99
This is my first time at this site.I was about to either buy a new TV or call a repair man $ 80 plus dollars and parts?
But I decided to ask perhaps this is some simple thing?
Growing up I fixed my own radios and TV's BUt now these new sets are great.
Here is what happens Bare with me here> I turned the TV on this morn.and it was black nothing.ON STRIKE!
I removed it from the dig cable box and hooked the cable line straight into the TV
I got good sound. I clicked the TV power button on and off about five or six times then it came on ( perfect ) then after a min. the screen scrolled up and out to black
again.I noticed there is this red light at the center of the TV's bottom frame that blinks off and on constantly, it says" stand by "The TV instructions manual says if this happens to call Sony Repair!
If you think this is a simple fix I will call a repair man If I knew someone that"s really good?
    Uploaded 5 video answers.
  • 152 Answers
Well i went through three user manuals.
and the all say the same thing
call sony..
that model is not a U.S model. its canada .
Posted on Dec 31, 2007
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
I have a sony 27 Trinitron with tuner issues. the picture is fuzzy/snowy on most channels. I have inspected the cable coax and it is not an issue. the problem started shortly after an electrical storm. I...
The RF amplifier in the tuner has been damaged. You will need to replace the tuner. A suitable replacement tuner from a wrecked Sony tv would be you cheapest option.
Best regards Vintie
Oct 08, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Can you please advise which external tv tuner will work for SONY trinitron kv-xf21m80 model? My SONY crt tv tuner is not catching most VHF B/G channels. i sought the services of an authorised service...
If you have a cable box and can set your TV to channel 3 then you should be able to watch cable. If you want to watch over the air broadcasts then you need a digital converter box which you can buy at Best Buy for around 40 dollars. You use the converter box as the tuner and set your TV on channel 3.
Dec 24, 2012 | Televison & Video
My new (used) Sony Trintiron recently took a fall and the screen was damaged. The damage appears to be a gash approximately 4-41/2 inches long and 1/4 inch wide. Is there a way I can fix this or get a...
The tv CRT-(tv tube) screen itself is broken now or dying already and tv PCB board broken require replacing too,tv will still work after replacing PCB board or repairing it but tv will not be watchable becauuce tv screen will all mess up like screw up picture colors will have black and blue colors be all over the tv screen.Tv now will not be worth repairing if require replacing CRT-(tv tube) will cost the same as a new tv if tries replacing CRT-(tv tube) if u still can buy it.Can't buy analog CRT-(tv tube) anymore.Sorry time to buy a new tv.
Apr 14, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Need Sony trinitron color TV receiver model no. kv500 users manual repair mainual
Your Sony trinitron color tv user manual available in this site click Here
Aug 30, 2010 | Cameras
Sometimes the color stays, sometimes the picture is in black and white?Sony WEGA Trinitron with TimeWarner cable box.
that problem is very common in a sony TV the main cause of that problem is the video can replace it with a new I.F. just adjust the I.F. to do it open the back cover of your can see the tuner soldered on the pc board.using a soldering iron and a desoldering pump take out the tuner from the board..remove the stainless covering of the tuner and soldered it again to the board there are two IF(intermediate Frequency) on the tuner the sound I.F and the Video IF.After soldering the tuner to the board power on the tv and use a plastic jewelry screw or an alignment tools then turn clockwise/counter clockwise gradually and slowly untill you reach a good carefull when adjusting not to touch with your hand the high voltage section...good luck hope I helped you Please vote for my help.
Jul 27, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sound but no picture
sounds like the tuner got hit by lighting. Cost of tuner unknown to me at this time have seen them from 20.00 to 100.00 dollars pluss shiping and then have to pay repair shop to put it in. You probley would be better off buying a new tv there is no telling what else could be damaged that would show up at a later time like in a few days to a month or so.
Feb 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony TV snow at startup
Bad solder connection in tuner.....replace with new or rebuild.
Mar 09, 2008 | Televison & Video
TV does not turn on.
Sorry, it sounds like to me that the power supply or high voltage circuits have failed. You will need to take it to repair shop.
Feb 19, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV-32V65 TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
