Question about Uniden BC246T Handheld Scanner
Programming my bc246t
When I plug my scanner into my pc and error comes up. It says not connected to scanner check remote connection.
  • medicman357 Jan 09, 2008
    not working
  • Retro88 May 22, 2009
    I have the same problem and have tried all com baud rates under the menu. Scanner came w/ a COM port connection.... most newer computers do not have a COM port. So I found a USB that works for the scanner. But the computer does not recognize the scanner.
Hello Ranger66,
I had the same problem. did you set the radio to "xfer information"? if not, to do this follow these steps
1. press menu display ---menu--- and program system under
2. twist thr top right knob until "xfer information is displayed".
3. press the "E" or yes button, this will disply the baud rate.
check to see if the radio connects.
Posted on Jan 01, 2008
I have a uniden bc246t how can i get it to load channels, scan hold nothing stored
Rather than loading frequencies via software, try programming manually, if that's going to be to hard, perhaps getting hold of a copy of the user manual (available from Radioshack or similar store) and it will tell you how in a step by step way.
You must have a list of frequencies in hard copy format to be able to do this, I've never used software to program my scanners, including my Uniden UBCD996T digital scanner, after all, half the fun is programming your favorites manually, so you learn how the scanner works.
I hope this is useful to you.
Cheers,
Peter
Feb 19, 2013 | Uniden BC246T Handheld Scanner
How to program my uniden bc72xlt police scanner
The best programming instructions are in the factory manual that you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Dec 30, 2010 | Uniden BC246T Handheld Scanner
Hello, my BC246T scanner has no sound, but it stops on different frequencies. I took the back off and try , checking the circuit boads, but did not solve sound problem. Is there anything else I can try. I...
Sorry, but the only mute function is in the external speaker and headphone jacks. Plugging into either one will mute/disconnect the internal speaker. Your scanner is about six years old, so it's possible that the speaker has quit working or that you have a problem with the audio amp. Try connecting either headphones or an external speaker to the appropriate jack. If you get audio through either one then chances are that you internal speaker is shot. No audio at all indicates a circuit problem that needs professional help. You local Radio Shack store can help with either problem. If they don't have the proper speaker in stock they can order one for you, and they can also arrange quality repair of your scanner. CAUTION: If you go the repair route, be sure to get a firm price, not just an estimate before you commit. Repairs can approach or exceed the cost of a comparable new scanner. Good luck and happy scanning.
Bill B
Oct 05, 2010 | Uniden BC246T Handheld Scanner
I just upgraded my firmware to version 2.6...will this scan garland, tx police
If Garland is using a conventional system or an analog trunking system, the BC246T can handle it. If they've gone digital, there's nothing you can do to the scanner to pull them in. For a list of the Garland systems and frequencies, check RadioRefernce.com or CityFreq.com
Nov 20, 2009 | Uniden BC246T Handheld Scanner
Need Program for Uniden BC246T scanner
scannow.org it is a free programming software
Apr 02, 2009 | Uniden BC246T Handheld Scanner
Programing a uniden BC246T
Not all programming software supports usb. Either find software that supports usb or you can buy add on cards to your pc that will give you a serial port. Hope this helps
Jan 26, 2009 | Uniden BC246T Handheld Scanner
Trouble programming my new Uniden scanner
go to www.radioreference.com and look in the uniden forum, they have everything you need to know there
Jan 02, 2009 | Uniden BC246T Handheld Scanner
Cannot program my bc246t
There are two ways to program your scanner. One is to do it manually. The second is to use a computer. The easiest way especially if you are programming alot of frequencies and alpha tags is to use a computer. Having said this I believe that you first should learn how to program manually so that you understand how the scanner works.
Email me and let me know what area you live in and give me an idea of what you would like to listen to. I may be able to help.
elijam1
elijam1@ameritech.net
Dec 18, 2008 | Uniden BC246T Handheld Scanner
Check here to see if the info your looking for is there, just punch in your state and county and the info listed beside the freq's should tell you. Hope this helps,, Mechanic
http://www.radioreference.com/apps/db/
Dec 27, 2007 | Uniden BC246T Handheld Scanner
Uniden BC246T Handheld Scanner Logo
237 people viewed this question
Top Uniden Radio Communications Experts
Steve
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
