Sharp R-510HW 1200 Watts Microwave Oven
Problem for Sharp R-510HW 1200 Watts Microwave Oven
Sharp microwave 1200 watts keypad showing
By rfossitt on Oct 24, 2009
Sharp microwave keypad showing wrong numbers such as 5C instead of 2:00 minutes. Everything else works fine. Tried unplugging and plugging back. Oven has been unplugged for 3 months. Problem occurred when started using again.
Solution #1
posted on Oct 27, 2009
Not Rated)
rlwilsonjr
Rank: Apprentice
Rating: 0%, 0 votes
Not a complete answer, but may help describe problem: Our R-510B should be the same except for color, and for several years it has intermittently messed up its display. The left side two segments on the units digit won't light up. So a digit 8, without the two vertical bars on the left, comes out as a letter E reversed left to right. Any digit that uses the two left segments (traditionally labelled segments E and F when talking about 7-segment displays) comes out wrong. Every thing else works fine. I can't tell if this is your problem.
This is almost surely a bad contact at the interface between the LCD display panel and the PC board: Typically there is a "squishy" conductive strip that connects them, and I expect grease has gotten in there. If so careful disassembly and cleaning with a mild solvent should fix it. Since we can live with it, and it usually fixes itself in a few weeks, I have not got around to taking it apart.
Bob Wilson
Was this helpful?
Yes
No
Popular Solutions for Sharp R-510HW 1200 Watts
Questions and Unsolved Problems for Sharp R-510HW 1200 Watts
Do you recommend Sharp R-510HW 1200 Watts Microwave Oven?
Answer
Answer
I have a Sharp Carousel 1200-watts microwave oven which is not warming up the food. I suspect it is... (More)
Answer
Do you have the capacitor for a sharp microwave, model r9560? Sharp P/N RC-Qz0100MREO
Answer
how do i turn off the "LOCK" on the screen. I do no tknow how it got turned on. Thanks
Answer
In my Microwave oven, BPL Sanyo Make, The light and turn table starts immediately on opening of the... (More)
Answer
Trying to replace our Sharp Carousel microwave but cannot get it off the wall.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp R-510HW 1200 Watts...:
Top Microwave Oven Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Microwave Oven Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
