Question about Kenmore 44832 Front Load Washer
KENMORE ELITE HE 3- MODEL 44832200
HELP!!!! I bought a washer and dryer set in 2004 and the washer is not working right. It will wash but when it comes to spinning it starts to click like teeth on a machine. It seems to try to spin. Sometimes it will get some water out but they are still soaked. I dont know how to fix this and I dont have the money for a repair man to come and look at it. Please help me if you can....
S.L.
  • 2 more comments
  • 199105 Dec 31, 2007
    Yea, the drum will turn to wash but, as soon as the spin cycle starts it humms and a fast clicking starts.
    what do you suggest I do.
    Ok I will try it right now.... Thank you for your time.. I really appreciate the help.... (smile) oh, and I'll remember the to remove the clamp... lol
    Ok I did it!! The clicking sound went away... and OMG.. I did not know how much stuff could get stuck in there.. money, batteries, and christmas hooks.. the grinding noise is still there, but, it spinns and spinns well now... lol do you think the motor is going out. I dont understand why the noise is still there.. But either way you help me get some loads done. Thank you so much... I wish I could give you a hug..
    President:
  • 1,314 Answers
Is the washer full of water and is the sound like a fast clicking
Posted on Dec 31, 2007
  • 1 more comment
  • robert samples Dec 31, 2007
    ok i think you have something stuck in your drain pump unplug washer from outlet before starting . facing the washer remove the two screws and remove the bottom panel if you have a wet dry vac then open washer door and pull the drain hose out of the drain and use the wet dry vac to vacuum the water out of the washer you will hear through the door when it is empty if you do not have a wet dry vac go to the auto parts store and buy a radiator hose clamp. There only about 5 or 6 $ will save you alot of mess. Look in the bottom of the washer underneath where you took the panel off and you will see a small motor. It will have a round white face and two hoses clamp the hose with the radiator clamp tightly. On the round white piece that looks like it has a bar across it turn it to the left, and remove it. Clean anything out that you see, such as coins strings ect, and check the impeller for broken blades buy looking into the pump itself. And if any are broken you will have to replace the pump. If not reassemble and don't forget to remove clamp lol. I forgot once
    vacuum the water out through the drain hose
    they may still be something in there you missed but long as its working use it you may have to replace the pump if it goes out all together one day but not now when you get caught up you can go back in and look with a flashlight into the pump if the grinding dont stop also take a light and look closely at all the holes in the tub like a nail or screw and is lightly scraping the inner tub and tell everyone to check their pockets before washing clothes lucky you have a kenmore as they are built by whirlpool other washers don't have that screen also you should thank the webmaster for running that site
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
I have a Kenmore washer model #110.20022011. The other day it did not spin out all the way, now it will not start at all. The fill light and lid lock light comes on, but it does not start. Water and...
A friend of mine bought a Kenmore washer model 110.20022013 a year ago. Now washer stopped in the middle of washing and a clicking sound starts, and not washing or rinse or draining
Aug 22, 2011 | Kenmore Washing Machines
Equator Wash dial just spins
just bought this ez 3600cee it says its ventless ,but yet came with
a venting duct work why?
Nov 29, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Noisy dryer
i had same problem with washing machine. i found out it was the stone inside which holds it down while it spins. The screws or nuts or what ever is holding the stone could be loose.
Or it could be the nuts or screws of the actual drum that spins that got loose when you moved the machine
Nov 10, 2007 | Washing Machines
Kenmore 44832 Front Load Washer Logo
280 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
