Question about SanDisk Sansa e250 MP3 Player
Mp3 player c200 sansa keeps freezing!!!
Hey guys...i really need help. my mp3 player keeps freezing up. is there any software i could downlaod to unfreeze it or some advice that could cure it? thanks a billion!
  • 758 Answers
FIrst you will need to reset your device..then go to the sandisk website to get the latest firmware for your device..To reset the device when it freezes just hold the power button down for 15-20 seconds or until it resets....the latest firmware for the c200 resolved much of the freezing issues....also there are two modes for you to use the c200 the msc and mtp.....try deleting in mtp mode.
Posted on Jan 03, 2008
That does so work idiot!!!
Posted on Jul 30, 2008
ThAT DOESNT WORK
Posted on Mar 01, 2008
PLEASE Help with my sansa c200 mp3 player!
The Sansa c200 has 2 versions, version 1 and 2.
Check the version of the player:
Go to Settings > System Info.
Information for the firmware version and SD cards support:
For 01.xx.xx firmware (c200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (c200 version 2) - up to 4GB microSDHC cards
Note: Firmware is not interchangeable.
Manual for c200 series:
http://mp3support.sandisk.com/downloads/um/c200-ug-eng.pdf
Manual for c200v2 series:
http://mp3support.sandisk.com/downloads/um/c200v2-um-eng.pdf
For deleting files connect your player with the computer.
When running Windows Media Player 11:
1. Check the automatic SYNC routine for your player.
How to get to the SET UP SYNC
When viewing WMP11 in full mode select SYNC or LIBRARY in the top of WMP11, seeing the Sansa player listed on the left.
Right click on the player and select SET UP SYNC... to go to the SYNC options.
When "Sync this device automatically" is selected, all playlist in the computers' Library will be transferred to the player again, even the previous deleted files. Disable this function to prevent unwanted SYNC.
2. Remove playlists from the library in set up sync, to get the playlists you would like to keep on the player.
Need more help ? Just post a comment.
Dec 10, 2009 | SanDisk Sansa c200 MP3 Player
No software for my sandisk sansa c250
This will give you the links to the Sansa Firmware Updater and Sansa Media Converter for your c200 series:
http://www.sansa.com/support/sansa_c200/faqs
-Tha Mp3 Doctor
Feb 28, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Software
problem in software SanDisk Sansa C140
Oct 10, 2008 | SanDisk Sansa c140 MP3 Player
Free memory
Format
This will format your Sansa c200 player’s internal memory
1) Select Settings from the Main Menu.
2) Select Format
3) Select Yes to format the internal memory or No to cancel.
-Tha Mp3 Doctor
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Aug 03, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Please free memory
-Tha Mp3 Doctor
Problems with mi Sansa
Reset the player, reformat it in Windows Media Player, then restart your computer. Worked for me after a bit of trouble.
-Tha Mp3 Doctor
Feb 21, 2008 | SanDisk Sansa c200 MP3 Player
I don't know how to load music from the internet to my new mp3
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel1.gif Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data1.gif folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 28, 2008 | SanDisk Sansa e200 MP3 Player
Need instructions
I don't know if you have found intructions yet, but I had to print mine online. Just go to sandisk.com/Assets/File/Downloads/user-guides/c200-ug-eng.pdf I know that's long, but hey, it pops right up. Good luck.
Jun 11, 2007 | SanDisk Sansa c200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
285 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
