My camera c633 takes photos but flash wont work????even with new batt???
When i take a pic i can hear the flash clicking but it doesint give a flash?? is the bulb gone?? all my pics are dark im lost without it ..can anyone help??
thanks,
Don Sweeney
It is eathe the bulb or the flash circuit. if you are going to fix it yourself watch out for the flash compasitor. If you are going to send it in watch the cost. It sould be fairly cheap to have fixed.
I have Same problem with same camera. I called Moultrie they told me to hard reset and walked me through steps. I am going to try it out when i get home. Hope it works or they will be hearing back from me
the driver makes it work the computer detects it try www.regfix.com it should set your sys right as most microsoft programs will download your photos for you
how long do you usually charged the batt? to make charge last slightly longer leave the batt inside the charger for an hour after the charger light goes off. if you have a fully charged batt you should be able to take approx. 300 pics or 2.5hrs approx.batt life. for viewing pics it should give you approx. 6800 pics and approx. 5.5 hrs. of course, number of still images and and batt life may vary depending on the camera settings.so if you're zooming in and out,using the flash,going from camera to play mode, turning cam on and off, using other settings and features of the camera, this will cause the batt to drain much faster.also ambient temperature also affects batt life.if it's very cold, the batt drains a bit faster.also, it's recommended that if you're not using the camera to remove the batt.retaining the camera settings, date & time will cause batt to drain even if your not using it. if did this and still you think it's odd that your batt drains quickly and looses charge even if it's fully charge, it might also indicate that what you might be a defective batt. one way to find out is to try using the same type of batt from a friend or a relative that has one to confirm and further isolate issue.anyway, supplied accessories has the same warranty that applies to your camera.so you may send it out and have it replaced if needed.hope this helps.thanks:)
The reason this problem occurred is that you likely never formatted the card. The card will work fine in the beginning for the first few shots, but eventually will corrupt. But don't format that card just yet as it will erase the card.
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
Hello!
Southern Photo Technical Service is a Authorized Service Center for NIKON.
It sounds like a circuit issue!!
We do service the camera model you mentioned and the standard cost to Clean, Lube, Repair and Adjust all functions to meet manufacturers
specifications is $125.00 plus return shipping.
All repairs have a SIX MONTH WARRANTY!
Include a copy of this reply and
receive a 5% INTERNET discount on your repair!!
Bring it in, or
Pack your equipment securely and insure it properly.
Send it to:
37 NE 167th Street
N. Miami Beach, Florida 33162
305-653-7355
try replacing the batteries with new ones, and if it persists you should contact casio customer support.
hopefully you're still within the warranty period, because they will over charge even on minor repairs(they all do).
there is a problem with the shutter mechanism, either electronic in nature, or mechanical. the click you're hoping to hear is the shutter release, and its not releasing.
give them a call, get a repair estimate, and if its too high try finding a repair person with good hands that wants to have a go at it.
nothing but good luck ;]
Sounds like the file allocation table on the card got screwed up. Try Googling Compact Flash Data Recovery. I know you're not using compact flash cards but the techniques for data recovery are pretty much the same regardless of the media. If and when you're able to recover what you can, I wouldn't use that card anymore myself. Good luck!
