Question about RCA D52W135D 52 in. TV/DVD Combo
RCA G35830WK will not power on
The TV went off a few nights ago and now will not power up with the remote or the button on the TV. There is definitely power to the cord.
0 characters
1 Points
Rca tv vcr combo model #T 13072 when I press the power button the power light blinks 4 times, tv does not respond. I have tried unplugging it for a few hours to see if it would reset but didnt work..
There is no power button on the remote, you have TV and VCR only to turn on this set. I need to find out how to do a factory reset. I was using a roku TV device on it, and was working fine, and now nothing. I tested the TV by putting in a cassette, and hooking it up to my satellite service, works fine doing that. But now no roku, and the roku was also tested and works fine.
Mar 10, 2012 | RCA Combination Televisions
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
My remote control for my rca combo 20f510td is not ejecting my dvd from the t.v. .... also actually none of the dvd buttons are doing much of anything when I press them, i.e. the play, pause, eject,...
For remote control concerns. You can try to reset your remote control but be shure before you reset your remote your tv should be unplugged from the power outlet. So here are the 4 steps to reset your remote:
1. remove the batteries,
2. press and hold the number 1 button of the remote control, thus draining all the remaining electricity.
3. put the batteries back in.
4. plug the tv on the power outlet then turn the tv on and try the remote control.
Now if these steps do not work check the warranty of the tv and have your remote be replaced if it's under warranty and if not you can try to purchase a universal remote control that supports RCA tv's.
Sep 09, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
My RCA model D52W20 will not fully power on when we try to turn it on by using the power button on the tv or by using a remote. There is a click and the green light that shows power lights but the tv does...
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
Mar 20, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
Tv won't turn on either manually or with remote
Jan 23, 2009 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
TV/VCR/DVD Combo won't turn on. Power button lights for 2 seconds
You have possibly
A blown fuse - likely
A faulty power board -likely
A broken power button -unlikely
Note that the voltages inside a television are deadly and I would recommend having the tv looked at by a professional.
Try unpluging the tv and plug it back in after 30 minutes, that should be enought.
Jan 07, 2009 | Toshiba Combination Televisions
Big Black Square
It turns out that the Closed Caption option was turned on somehow. When I turned that off the Black Square went a way and did not return.
Sep 14, 2008 | RCA T19408 19 in. TV/VCR Combo
Dish Network remote code for RCA 20F510TD TV/DVD
hello and please help.
want to know the codes and way to program this rca dish remote model RCR500SAM1 for my Toshiba tv.
ive done it a few years ago but forgot.
so i need the codes for toshiba tv and way to program this rca dish network remote.
Jul 26, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
RCA D52W135D 52 in. TV/DVD Combo Logo
273 people viewed this question
Top RCA Combination Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Combination Television Expert? Answer questions, earn points and help others
