Home | Bissell | 9500 ProHeat 2X CleanShot Upright Deep Cle... | Is not sucking
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Problem for Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner,...
Is not sucking
By luliforfar on Oct 24, 2009
is not sucking. Water comes out fine, but when the trigger is released, the water does not get sucked back.
Best Solution
posted on Oct 24, 2009
Very Helpful)
macgivor
Rank: Guru
Rating: 95%, 29 votes
Without more input from you, it is difficult to know what the problem is. Do you hear the vac motor wining ? If so, then ther is a clog in the passage or there is damage to the vac motor/impellor blade. If no sound from vac motor, well of course it will never ****-up the water. YOU WILL NEED TO TAKE IT TO A GOOD HANDY MAN OR AN APPLIANCE REPAIR/VAC REPAIR CENTER. Good luck, Macgivor
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" thank you macgivor " - luliforfar
Popular Solutions for Bissell 9500 ProHeat 2X
Questions and Unsolved Problems for Bissell 9500 ProHeat 2X
Do you recommend Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum?
Answer
Answer
I'm having trouble inserting the new bladder. Everytime I get it in the bottom and put the valve in... (More)
Answer
does not apply solution to floor.this unit is less than 8 mo. old. it is a bissel pro 2x
Answer
dirty water not being sucked up. machine seems to be blowing out hot air
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bissell 9500 ProHeat 2X...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
