Question about Toshiba 32AF53 32" TV
Remote doesnt work. tried changing batteries and cleaning bulb on tv. i usually use the remote for my dish. it works on the dish but not on the tv for sound ,on or off, channell changes etc.
  • sknobl Nov 25, 2008
    We have three sets of the 32AF53 all of them have problems with the remote. Seems Toshiba has a problem with the remote receiver or equivelent circuits. Has anyone seen a recall or if Toshiba will fix this free. Looks like an engineering defect!
    Genius:
  • 1,694 Answers
Pull chassis...solder connects on IR sensor...test = ok ? .done
Still not working = replace sensor ...........T.
Posted on Dec 31, 2007
Dish remote doesn't work when tv is first turned on. After about 10 min then it will work. What is the problem. I can change channel on control panel on box itself.
You are receiving IR interference from the fluorescent bulb in your tv heating up.
The best resolution would be to contact dish to confirm if your remote can be switched to UHF or if can get one that will.
You may also try repositioning your box slightly as long as it doesn't require un hooked the cables.
Mar 01, 2014 | DISH Network Televison & Video
MY DISH REMOTE STOPPED WORKING
1) clean contacts batteries and clean.
2) retigh the spring with pliers very well for better contacts.
3) resolder the wires contacts batteries for a good contacts
4) open the remote c and clean the keypads for dirty, oxide with special spray contacts cleaner.Resolder all colder joint points.
5) Try again.
6)I f the problem persist you must go to the repair shop TV for fix it or change by new R.C.
God bless you
Jun 27, 2012 | DISH Network Televison & Video
TV 1 does not pick up Dish, scanned but doesn't show Dish
1) change the new batteries
2) Clean the contacts batteries very well
3) retight the springs contact for better contacts batteries
4) Open the remote and clean the keypad with special spray contacts cleaner.
Otherwise you must go to the repair shop.
download again the code: www. fitness.manualsonline.com
God bless you
May 23, 2012 | DISH Network IR Remote Control
TV Remote control stopped working. I changed the
It depends. If this is a remote for a satellite receiver, you may need to resynch the remote (see your manual - I know the Dish instructions).
If this is a TV only remote, you might try opening it and cleaning the contacts with an can of compressed air, electronic contact cleaner and a clean pencil eraser. However, recent remotes are like keyboards (membrane contacts) and this doesn't always work. In that case consider a universal remote to replace the bad one or look to see if remotes.com has a duplicate of your remote.
I hope this helps.
(for Dish, it is turn on the TV and the receiver, hit the Sys Info button on the receiver, then hit record on the remote. Then hit Select on the remote.)
Apr 24, 2010 | Televison & Video
My remote show it is supposed to work but when i try to turn on my cable with my dish remote it doesn't do anything
  1. open the door on the right side of your receiver and press 'Sys Info
  2. press record multiple times on your dish remote
  3. press select
  4. if this doesnt work change the batteries and try again
  5. if this doesnt work call Dish for a new remote
Jan 26, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Dish network remote stopped working for on and off and volume
First before trying to repair the remote lets try to just reprogram it. The easiest way to do this is to do a search. 1st Turn the tv on, then on the remote press and hold the tv button until it flashes. Next press the tv power button. Next press the up arrow button slowly until the tv turns off. Then hit the # key. Now if you pressed the up arrow to many times and the tv doesn't respond to the remote just start the process over, except using the up arrow use the down. You may have to push the up arrow button many times before it finds the code. The batteries usually last quite a while since there are 4 of them. If this doesn't work call 1-800-333-dish they will either send out a tech or just mail you a new one. If you have the user guide for the 722 the instructions to do this are on page 82.
Sep 16, 2009 | DISH Network IR Remote Control
Doesnt work
try putting new batteries if that doesnt work then reconnect the remote to the tv
Jun 12, 2009 | DISH Network IR Remote Control
Dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
Echostar IR remote (Dish)
to set remote to tv
3)press pound sign
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Apr 30, 2008 | DISH Network IR Remote Control
Hay
You can take out the batteries for 20 seconds, then put them back in. Generally if that doesnt work, try to replace the batteries. If that still doesnt work you might have to reset your remote in order to get it functioning again. Let me know if you have done those steps or were you are at after you do this.
Sep 20, 2007 | Universal Remote Control Dish Network...
Toshiba 32AF53 32" TV Logo
90 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
