Question about Jenn-Air JCD2389G Side by Side Refrigerator
Fix it fridge
Jenn-air side by side fridge door ajar ran constantly while away for 3 days now will not get cold enough seems to be a problem with defrosting of freezer unpluged and defrosted but still not getting cold enough stays around 55
    Master:
  • 619 Answers
The compressor does not properly run ,motor valve weak ,test w/ amphere meter if does not match w/label amphere , comp. motor problem.
Posted on Dec 31, 2007
Jenn-Air side by side refrigerator, Model JRSD2490. Not staying cold enough
Larger=colder. Make sure that 1) your magnetic strip around the fridge door is sealing well. Even a small leaking area could make it difficult to keep cold, especially in warmer areas. Also, make sure there is nothing obstructing the door from closing completely and sealing properly. I had this same issue where one of the door shelves was unlatched a little and the door would close but not seal. Beyond that could be motor or more likely compressor or coolant leak. Good luck.
Jun 20, 2014 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Damper Door fell off. How do I put it back and what will happen if I cant?
Not knowing exactly how you broke it off, its hard to say just how its supposed to go back on. Since these are usually screwed into place, or in some cases its a snap tight fit, something is definitely broken, and you will likely need to replace the damper door. If you do not fix this properly, you will not be able to adjust the fresh food temperatures, and in fact you may freeze your refrigerated food, or it may be not cold enough to keep food fresh at all.
Feb 01, 2011 | Jenn-Air JCD2389G Side by Side...
Freezer Cold Fridge not cold, vents clear of obstructions. Vent at top left of fridge making a clicking sound, some cold air coming out of vent, probably not enough,Freezer control on 2 ,Fridge control on...
Need to defrost fridge completely for about a day then switch on again. Possibly door was left ajar on freezer, or auger motor iced up due to product being to close to outlet..
Sep 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice not strong enough to push open ice maker door
twtw7771
You said,
The ice maker door seems to have a tight spring or something because when the ice goes in the chute and then backs up.
The door needs to be replaced because it is bent or out of alignment!
How old is the fridge??
Now a days you have a 1 year warranty!
Or the seal is not tight and air gets inside past the door and then the moisture freezes on the spring.
Sep 20, 2008 | Refrigerators
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JFC2089HES (French Door) Fridge not cooling enough
Hey Northrock,
Did you ever get your fridge fixed? I have the exact same fridge and the exact same problem.
Nov 22, 2007 | Refrigerators
Referidgerator side is not cooling?? Help?
I had this problem. Here's what I found: The cooling core on the freezer side was froze up. Covered in ice. I think the reason this happened was that the freezer door was held open by one of the slide out trays just enough to pull in outside air. Don't know how long it was like this. When I found it (and corrected it) the interior of the freezer was covered in ice crystals. From then on the refer side contents began warming up. There was no flow of cool air to the refer side from the freezer side (this cool air comes in from the freezer side fan near the top left side of the refer side). Freezer side was near zero temp and the unit ran continuously. Here's what I did: Removed everything from both sides (put it all in another fridge/freezer). Turned off (or unpluged) the fridge and left it off over night. I put towels under the fridge because there can be an over flow of water that could go to the floor. It works great again.
Nov 03, 2007 | Jenn-Air JCB2389G Stainless Steel Side by...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
145 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
