Question about Whirlpool GS6SHEXNL Side by Side Refrigerator
WHIRLPOOL CONTROL PANEL
I HAVE A WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE. THE LIGHT AND TEMP DISPLAY IS NOT WORKING ON THE REFRIGERATOR SIDE, BUT THE FREEZER SIDE IS WORKING. THE REFRIGERATOR IS KEEPING TEMP JUST FINE.
ANY IDEAS???
  • 5 more comments
  • harroyave1 Jan 01, 2008
    I HAVE A WHIRLPOOL GS6SHEXNB00 SIDE BY SIDE. THE LIGHT AND TEMP DISPLAY DOES NOT WORK ON THE REFRIGERATOR SIDE, BUT THE FREEZER SIDE IS WORKING. THE REFRIGERATOR SEEMS TO BE WORKING.
  • Cecee Jan 04, 2008
    Exact same problem here...same model too. So....what is it and what can I do?
  • TD49 Jan 14, 2008
    Same problem, lights on control panel are off. Refrig appears to work. Same fridge...I have the ML, not NL but believe that's simply a color change.
  • St georgie Jan 14, 2008
    I have the same problem - when the light bulb went out and I replaced it - the temperature and control panel went out.  when I take the bulb out the control panel goes back on.  I am interested in any solutions posted before I have to call a repairman.
  • caesar123 Jul 21, 2008
    Same issue here. GS6SHEXNB00 model. Fridge works but no display and no interior light.
  • whirlpoolfri Jul 29, 2008
    I have the same problem, the control panel is not working and the light for the refrigerator side not working but the freezer light works. Same fridge also.
  • jdow8 Sep 09, 2008
    I have this same problem no light or display on refrig side only. But still works ok. Also it makes a buzzing sound when you open the door like a relay chatter.
    Scholar:
  • 27 Answers
Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
Posted on Feb 02, 2008
    Master:
  • 619 Answers
The temperature "switch are stuck "/ no temperature display and light monitor.
Posted on Dec 31, 2007
2 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE REFRIGERATOR LIGHT
funny you asked this question i just had this same problem this week at a customers home. you need the electronic control board located in the compressor compartment behind the refrig. it is mounted in the white box on the left hand rear corner. the whirlpool part number is 2304095 and it is around 175.00 i'm not sure who a local part supplier around you would be if all else fails you could get thru sears..
Posted on Jan 07, 2008
Mother board for whirlpool refrigerator GS6SHEXNL00
Do you need the electronic control board for the GS6HEXNL00? That is part number: W10135090 . Sears Parts Direct has the board in stock: http://www.searspartsdirect.com/part-number/w10135090/0046/106.html . This is part 18 on the diagram here: http://www.partselect.com/Models/GS6SHEXNL00/Sections/UNIT-PARTS/?ModelID=808745&ModelNum=GS6SHEXNL00&mfgModelNum=&ManufactureID=3&Selected=2D0VFYGP&Position=12&mfg=Whirlpool&Type=Refrigerator&Mark=12 . Parts Select lists this part as on order but it can be added to your cart.
I hope this helps.
Dec 29, 2015 | Whirlpool Refrigerators
Refrigerator light and temperature display not working
Check that the wires going to the temp. display has power on them, if "yes" change temp. display......
Lights the powre goes to a switch on the door frame that sends power to the light in refrid.
Dec 14, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirlpool GB22DKXGW00 stopped working while connected to a power inverter during a recent power outage. The light still works so I know it's not an outlet issue. Fan's not moving, no humming, just silence.
I would check your defrost timer it will be located at the bottom of the ref under the kickplate. You can manually advance it by hand and see if the unit will kick in. If this doest not correct the problem then I would assume that you have a bad temp control or a shorted compressor winding. You can try tapping on the control panel by your temp control with the back of a screwdriver and see if the unit will kick in. Hope this helps _MJ_
Mar 04, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a Whirlpool sise by side thats about 4-5
you need a new control panel, if your light bulbs blow out it surges the control board and ruins the control board and your symptoms of no lights and temp control points to the control board
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
WHIRLPOOL AMERICAN SIDE BY SIDE FRIDGE /FREEZER
I had probably the same problem. After a little discussion with the factory they sent a technician as a "Good Will Gesture." The technician told me it was the control board down by the compressor. I overheard a conversation between he and his central repair office that it was a common problem. The factory would not admit it. I have a feeling the electronic control board he replace (which would have cost several hundred bucks) was probably made in China. Now I'm having more problems with my Ohio made Whirlpool side-by-side. The freezer is working fine, the fridge is not very cold. By the way, the internal lights was one of the keys to the problems.
May 21, 2009 | Whirlpool ES5FHAXS Side by Side...
Jan 06, 2008 | Whirlpool GS6SHEXNL Side by Side...
Whirlpool GD5RHAXNQ SIDE BY SIDE, CHIRPING NOISE WHEN LIGHT IS PLUGGED IN
short in the control panel. or the ground in the control panel is loose.
Dec 26, 2007 | Whirlpool ED0GTQXMQ Side by Side...
Whirlpool GS6SHEXNL Side by Side Refrigerator Logo
767 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
