Question about Food Mixers
Operating sound board during church worship services and during preaching
My church as a bk 1642 stereo mixer and I don't have a clue on operating it currently during services, recording the choir while singing or my pastor preaching. Please help Lorenzo at
0 characters
1 Points
Stand mixer doesn't work after the 5th speed
That's not the sort of problem you are likely to solve at home. There is a speed control pcb and a speed sensor involved, it's not mechanical like the other old models. Best you contact Kitchen Aid and find out where your closest authorised service agent is.
Apr 11, 2015 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid mixer kv25g0 stop working after five minutes
These mixers have a circuit board and sensor which govern its operation. The Service Manual may help:
The 5 and 6 quart machines are the same except for bowl capacity.
Sep 05, 2014 | KitchenAid KV25G0X Stand Mixer
My kitchenaid mixer run on high at all times
If your mixer only runs on high speed there are 3 things that can cause that. The first thing to check will be the speed control plate, Remove the trim and end cover on the mixer, the first thing you should see is the speed control plate, this has 3 screws on it, try adjusting the top two screws 1/4 turn, this should slow the mixer down, do not over tighten. Also check to see if the control plate spring is unhooked. If the spring is unhooked, attach to bottom of the control plate, and squeeze the spring end.
If this does not fix your mixer, check the wiring of the mixer, you can locate a wiring diagram on the last page of the service manual.
If the speed control plate is adjusted correctly and all the wiring is correct it will be your speed control phase board. You can test the speed control phase board to see if it is shorted. With the line cord disconnected, pull the t-b ar contacts to open, and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, teh phase control board is defective and needs to be replaced.
Here is a link to the service manual:
This will aid you in taking the mixer apart, troubleshooting and putting it back together, remember the wiring diagram is the very last page.
Thank you,
Customer Service
Jan 07, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
How do I get an owners manual for Ross mixer 12x2
What model of Ross Mixer do you have?
Dec 18, 2011 | Food Mixers
Mixer walked off the counter and bent the shell housing... Mixer works but is squeeking and has loose nuts inside...How do i open it up?
Customer Service Information
Before Calling for Assistance
Please read before calling:
• The mixer may warm up during
use. Under heavy loads with
extended mixing time periods, the
top of the unit may feel warm to
the touch. This is normal.
• The mixer may emit an odor,
especially when new. This is
common with electric motors.
• If the flat beater hits the bowl,
stop the mixer. See page 10 for
more information.
If your mixer should
malfunction or fail to operate,
please check the following:
• Is the mixer plugged in?
• Is the fuse in the circuit to the
mixer in working order? If you
have a circuit breaker box, be
sure the circuit is closed.
• Turn the mixer off for 10 to 15
seconds, then turn the mixer
back on.
• If the problem is not due to one of
the items mentioned above, see
Customer Service Information.
• DO NOT return the mixer to the
retailer as they do not provide
If you have a question about your mixer, call our toll-free customer service
number. Before calling, please note the model, type, and series numbers
and fill in that information below. These numbers can be found on the
bottom of your mixer. This information will help us answer your question
much more quickly.
MODEL:___________________ TYPE :___________________ SERIES: __________________
In the U.S. 1-800-851-8900
In Canada 1-800-267-2826
Sep 17, 2010 | Hamilton Beach 400 Watts 63220 Stand Mixer
Kp26m1xwh Kitchenaid mixer 575 watt stopped working.
On the back of the mixer is a screw holding on the Kitchenaid name plate band that wraps around the mixer. Remove this screw and the name plate and then you'll see four screws (two on each side) holding on the top cover for the mixer. Remove the four screws and then lift off the top cover and you'll see the motor, circuit board and gear box that operate the mixer.
May 29, 2010 | KitchenAid KP26M1X Stand Mixer
Variable speed
Based on the description of this problem it sounds like you may have a control board issue. When faulty this can cause erratic function, sparking, smoking, as well as complete failure. This requires some know how and should be done by an appliance repair shop. Part number for the main board is W10119326. Hope this helps
Jan 07, 2010 | KitchenAid K45SS Classic Stand Mixer
My epicurean mixer (5quart) stand mixer sounds loud but isn't overheating is that abnormal or if so what should I do
KAY – You don’t mention how long you’ve had your mixer or how intensely you use it, which would be helpful in assessing your question. Our first KA mixer we got in May 1989, seemed ‘whisper’ quiet compared to the replacement 6 qt Pro mixer our children got SWMBO for Christmas in 2006. The new mixer was so noisy that my wife called Kitchenaid to complain. The wonderful KA ‘Helpers’ explained that KA had changed to making all metal gears in their mixer transmissions as opposed to having one plastic gear (intended to fail instead of burning the motor out). That change from plastic to metal is then main reason your KA mixer seems to be much louder. You should be able to judge if your noise level has increased or stays the same during normal use. Since you stated that you don’t notice any overheating of the mixer I would say that the noise level is appropriate and wouldn’t be overly concerned at this point. That being said, if you hear a change in the noise level – usually louder, it could be indicative of mechanical issues in the transmission, which is what finally happened our mixer. One of the gear teeth broke and the agitator froze up. But that is another story…
I hope this helps. Good luck! Howard – Burke, VA
If this solution has helped you, please rate it, thanks!.hslincoln
Nov 27, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Hobart A200 Commercial Mixer
Manufactured in 1931. Want to sell it? My girl just opened a restaurant and needs one... All the best.
Nov 20, 2008 | Food Mixers
Kitchenaid Mixer K45SS
I just did this last week!
1 Unplug Mixer 2 Remove screw on TOP of mixer body, at back. 3 Remove rear cover and paper-gasket thing (its not the end of  the world if you end up tearing it a little). 4 the phase control (little circuit board w/wires) is at the top (you  should see it very easily) held on by one screw, remove it. 5 when the circuit board is unscrewed, disconnect all the wires  that are connected FROM THE CIRCUIT BOARD to the  black control plate (NOT all wires-there should be 4 left on  the control plate at this point).  you don't need to  remember where all the colors go as the control plate is  labeled->but looking at them and making sure you  understand the abbreviations would be beneficial  (BK=black, BL=Blue RW=Red&White W=white R=red etc.   6 install new phase control (screw), either buy new thermal  grease (used to keep the board cool->it transfers heat to  the mixer's housing) or try to salvage what you can from  the old one. 7 connect wires, paying attention to labels. 8 reinstall paper gasket, then cover, then screw to hold on back- cover.
Jan 17, 2008 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
177 people viewed this question
Top Food Mixers Experts
Custom Exchange
Custom Exchange
Colin Stickland
Colin Stickland
Are you a Food Mixer Expert? Answer questions, earn points and help others
