Question about Lexmark X125 All-In-One InkJet Printer
Sending Fax I have Vonage phone service connected to my computer and I'm trying to send a fax to someone with a Lexmark X5070 Printer/fax.  I can receive faxes from him but when I try to send, my fax says "send error" and will not send.  Can you help me?
Set baud rate to 9600 or slow
set resolution to standard
set error correction mode (ECM) off
if fax has overseas mode turn it on
vonage can make changes to the line that could help, if your using a voice line with call waiting use *70 prior to the number to disable call waiting for that call
Posted on Aug 20, 2008
I get a remote fax error when trying to send a fax...i have a Lexmark X5070 all in one printer/fax
The problem could be due to the quality of the telephone line connection. Try to resend the fax.
Lower the transmission speed. Follow the steps below:
  1. From the printer operator panel, press Fax mode.
  2. Press the menu button.
  3. Select Fax Setup.
  4. Select Dialing and Sending.
  5. Select Max Send Speed.
  6. Lower the speed to 9600 bps.
  7. Press check button.
Try to send a fax to verify that the problem is fixed.
Sep 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
I have a Lexmark mode lX3550. What do I have to do to make it fax?
Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. • The Lexmark Fax Software is installed on your computer.
Sending a fax using the software You can scan a document to the computer and then fax it to someone using the software. 1 Load an original document facedown on the scanner glass. 2 From the desktop, double-click the Lexmark Imaging Studio icon. 3 From the left pane of the Welcome screen, click Fax. 4 Select the Document option. 5 Click Start. 6 Enter the recipient information, and then click Next. Note: A fax number can include up to 64 numbers, commas, periods, and/or these symbols: * # + - ( ). 7 Enter the cover page information, and then click Next. 8 If there are any additional documents that you want to send with your fax, add these now, and then click Next. 9 To send your fax: • Immediately-Select the Send now option. • At a scheduled time: a Select the "Delay sending until" option. b Set a time and date. 10 If you want a paper copy of your fax, select Print a copy of your fax. 11 Click Send.
Aug 11, 2011 | Lexmark X3550 All-In-One Printer
How do I change baud rate on Lexmark X5650 in
Just to set your expectation, MagicJack phone service may work but Lexmark does not recommend the printer to be connected to a digital phone signal (e.g. MagicJack, Vonage, etc.) since there are lots of jitter and packet loss in the transmission signal resulting to fax failures. The Lexmark fax machine will have its optimum performance when connected to an analog signal(regular telephone line). But here's how to configure the printer's baud rate. From the Control Panel, press Settings(wrench icon)> Fax Setup, hit Ok > Dialing and Sending, hit Ok > Max Send Speed, hit Ok > set down the speed to 9600 bps. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 06, 2010 | Lexmark X5650 All-in-One InkJet Printer
HP 3380 All-in-one. wont send faxes. dials, says connecting, and even sometimes starts to send page, but comes up comm error. I have vonage phone service.
Vonage claims to work with all fax machines. However, some customers report having had trouble sending and/or receiving faxes with Vonage and other voice-over IP (VoIP) providers. The difficulties are a frequent topic in help forums and even made the Wikipedia entry for Vonage. Frustratingly, the problems have been intermittent and hard to diagnose, and some customers have resorted to buying a new fax machine that better-suits Vonage’s optimum specifications. The company’s official “help” resource suggests lowering the baud rate on the fax machine to 9600 (or “slow”) as well as disabling the machine’s ECM (error correction mode) feature, if applicable. Also, make sure the fax machine is on the “standard” setting. Some users have had good luck adding *99 before dialing, as that resets the bandwidth for that call.
Vonage also allows its customers to send faxes over the Internet, without a fax machine, by uploading documents to the Vonage web site. There is no additional charge for this service if you’re on the company’s “Unlimited Plan.” Per-minute customers will see fax use applied toward their monthly minutes allowance. Hope this helps.
Apr 20, 2010 | HP LaserJet 3380 All-In-One Printer
My Lexmark X4270 All in One will not fax, I have tried everything but it still won't work. I have Vonage as my Phone service and my computer runs through a Linksys router. Can anyone help me?
Faxing over VOIP is tricky and unreliable at best. Your phone system support people at Vonage should be contacted. This is not a problem with your Lexmark all-in-one product.
Jan 13, 2010 | Lexmark X4270 All-In-One InkJet Printer
Unable to receive fax data, i have it on auto anwser and fax mode. sender only gets ringtone. land line is connected to fax mach. please advise.
Test by sending fax to 1300 688 999. Results will be faxed back. Automated service. Cost of local call.
Ring your fax from your mobile when you are next to it and hear it ring and answer.
ADSL filters in place???
Nov 17, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
While sending fax i get an error message remote fax error? what does this mean
Sounds like a problem with the receiving fax machines phone line. Try send to another fax. If it is still doing the same thing, then the problem is in your line.
Jul 24, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Unable to send/recieve with my Samsung SF 565P fax
Plug a phone in to fax port, Is there a dial tone there also? can you dial a number and make a call from the fax port? You should be able to with a regular phone. If you can't, try plugging in the fax machine to the other port where your phone is plugged in. try sending a fax.If it works there, then the Vonage device or your service itself is the problem.
Apr 22, 2009 | Samsung SF-565P All-In-One Laser Printer
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax - Using Vonage
Press Setup on the All-in-One. Navigatet to Advanced Fax setup - Fax speed. Set the Fax speed to Slow. Also set the ECM (Error Correction Mode) to Off. Try sending FAX.
Dec 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Lexmark X125 All-In-One InkJet Printer Logo
340 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
