Question about Onkyo HT-S680 System
Problem w/ surround sound for Onkyo HT-R430
When I hook up the speakers to the receiver, I only get sound from the 2 front speakers (no subwoofer sound or even center speaker). Please help!
  • 1 more comment
  • Anonymous Aug 01, 2008
    i have this prob too the test tones work on all ch.s but will not allow sound through
  • meerkat32 Oct 09, 2008
    Have HT-R 560 receiver,when going thru set up and get to (3. sp config) , (4.sp. distance) and (5.level cal) cannot acess. Therefore,i can't configure or calibrate speakers???? all other functions on setup work,audio adjust-e.q- modes. Just can't figure out ...no instructios
  • Anonymous Mar 31, 2014
    How do I hook it up to my Sharp aqueous tv and speakers for surround sound?
You are in stereo mode which only uses the two front speakers, hit the surround sound button remote or hit the mode button and cycle through until you get to the Dolby II setting
Posted on Jan 01, 2008
You might have blow the fuse for those channels.
Posted on May 05, 2008
    Problem Solver:
  • 12 Answers
Are ou sure that your speaker wires it hooked up to the right holes they are suppose to hucked up to. try changing the hires around.
Posted on Dec 31, 2007
Onkyo HT-R693 (HT-S7700) receiver will play video but no audio on Netflix and YouTube. However, sound comes through when connected to Comcast cable and even Pandora. I have tried the different channels...
  • Check your cable connections
  • set the input selector to the proper component sources your using.
  • set your speaker settings to either 5.1 or 7.1, according to your speaker configuration via Onkyo's AccuEQ automatic setup tool- because the same binding posts can be used for hooking up the Atmos height or surround back speakers; you'll need to tell the Onkyo system which setup you're using.
Mar 08, 2015 | Onkyo Audio Players & Recorders
Hello I have another question but this is containing my back up surround sound receiver til I can find a Sony receiver that I like. Ok this receiver is a AV receiver model ht-r420 onkyo surround sound...
Subwoofer sockets
The HTR-420 has only a single subwoofer output. It is the socket on the lower left corner. The other subwoofer socket is part of the multi-channel input.
Because of the age of the 420, it comes from a time when optical and coax connections were not so common and DVD players had 6x phono/RCA sockets to send out the surround signal in analogue format. The multichannel input is for sending a signal in to the amp, and not for getting a signal out. That's why the sub doesn't get a signal from that socket. Use the proper subwoofer out. That's what it is there for.
Speakers A+B
The 420 was designed to run Speakers A+B together if required. However, you must observe the minimum impedance loading if you connect up two sets of front speakers and run them simultaneously.
The minimum Impedance for each set of front speakers is 8 Ohms. If you're recycling old surround speakers from a Home-Theater-in-a-Box system, or the speakers have no labels for impedance on the backs then you can be fairly sure they are not 8 Ohm. That could be the problem.
Sep 09, 2014 | Audio Players & Recorders
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
I have just set up my onkyo 5305 i only have sound to front speakers have checked connection but im lost now in the settings
Onkyo are known for having 2 seperate connections for the rear speakers. 1 set for a surround sound, channel "A", and 1 set for seperate set a speakers, channel "B". check for the second set of connections. Also, your only gonna get sound out of the rear speakers thru surround sound mode when the unit actually sends singal. The sound is determined buy what setting you have the receiver set to.
Mar 06, 2011 | Onkyo HTP-102 System
Surround sound speaker outlets are not working
Hello, I am sorry about your issue. If the speakers work on other terminals then it sounds like a problem with the receiver. It would need to be serviced or traded in. Please contact Onkyo at 800-229-1687 option #3. Thank you, Onkyo USA
Jun 24, 2017 | Onkyo HTR500 Receiver
My Onkyo TX SV 535 Surround Sound wont work
when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly.
and you select surround sound in listening mode.
Aug 17, 2008 | Onkyo TX-SV535 Receiver
Subwoofer ... it is hooked up, but no sound
I found a manual online, and learned that there is a speaker set-up procedure on this Onkyo model ... so when it got to the subwoofer set-up, I simply went from "subwoofer off" to "subwoofer on"
Jul 25, 2008 | Onkyo TX-DS575 Receiver
Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Apr 22, 2008 | Onkyo TX-SR605 Receiver
Righ & Left Front speakers not functioning
SOUNDS LIKE HE HIT YOUR SPEAKER CHANELS 1 OR 2,,, PUSH 1
Mar 15, 2008 | Onkyo TX-SV545 Receiver
Onkyo HT-S680 System Logo
1,439 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
