Question about Pentax ME Super 35mm SLR Camera
Pentax Superprogram SLR
I have a Pentax Superprogram SLR approx. 20 years old. The LED just stopped working. No reading inside or at the top. I've tried all settings and still no reading. I've put in new batteries, tried cleaning battery compartment with a pencil eraser. I've taken it into an authorized repair shop. Their feeling is it's a circuit problem and they aren't even going to attempt a repair.
  • Wetoad Jan 03, 2008
    Thank you for trying. That was the first thing I did.
It may sound silly, but have you changed the battery recently?
Posted on Jan 02, 2008
  • 619 Answers
Visit this :
Posted on Jan 01, 2008
How do I properly set the self-timer to work on a Pentax ME Super SLR?
Push the lever on the front of the camera counterclockwise until it stops. To start the self-timer, push up slightly on the lever.
If you need a manual, you may download a copy from here.
Jul 28, 2012 | Pentax ME Super 35mm SLR Camera
Pentax ME Super
Does the film advance lever lock in place when the lever is returned ? if not, the lock spring broke. This is a common weak point in the ME Super. the camera must be partially disassembled to be repaired. get a cost estimate first. there are no new parts for this model Pentax.
Jan 04, 2010 | Pentax ME Super 35mm SLR Camera
Pentax ES2; do bayonet lens fit digital Pentax SLR?
Any Pentax K-mount lens will fit any Pentax DSLR. The DSLR will fire the shutter.  There is a menu setting (RTFM) which allows the use of older lenses, but you will lose some of the automation (again RTFM). Remember to allow that the effective focal length when using a "film" lens on a DSLR body goes up by 50%.
A standard 50mm lens becomes a 75mm equivalent, but stays a large aperture.
Nov 25, 2009 | Pentax ME Super 35mm SLR Camera
Pentax ME Super: Mirror sticks in DOWN Position
The shutter & mirror is in need of a CLA. Clean, Lube & Ajustment. Its well needed for any camera when they are 20 years old and older
Feb 19, 2009 | Pentax ME Super 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button won't release
Common fault due to perished rubber parts. Can be usually be repaired, but do not try to force the camera, that may cause damage which can not.
Go to http:/ for information on how to service this yourself. The author can also advise by mail, and can service these cameras too.
Nov 23, 2008 | Pentax ME Super 35mm SLR Camera
Pentax Super ME
Yes, the ME super has an electronic shutter that works in conjunction with the LEDs. Purchase some fresh S76 button cells, A76 will work, but the will not last as long. Make sure the battery cover is corrosion free and install the batteries so both cells face positive toward the cover.
Jan 17, 2008 | Pentax ME Super 35mm SLR Camera
Manual Rewind Pentax PZ
Hi Joel,
If your battery is dead, just put in a new battery.
Go into somewhere that is completely dark and open the back of the camera and remove the film.
Or go Costco, WalMart and Kmart and they will do it for free.
Dec 13, 2007 | Pentax ME Super 35mm SLR Camera
My Pentax Camera Light Meter is not registering changes made to the Aperture Ring.
Take lens off to check the lens/light-meter coupler situated inside the lens mount at the top part of the mount at 'one o'clock' . First see if it moves freely ,clock wise. Then -with the lens off- look through the view finder while you activate the coupler : moving it should make the l.meter lights move up and down.
If you are not getting any joy the connection between the coupler and the board needs re-soldering ( dry joints ) : remove top cover and resolder two blue wires on left hand side of the board . This should do the trick.
Nov 30, 2007 | Pentax ME Super 35mm SLR Camera
Light meter failure and shutter button sticking
Set your camera to B and release the shutter ( camera will work in this mode without batteries ) if you can wind ok and release shutter fine then all you need is new batteries. If however your camera is not working when set to B then it is either the shutter or the transport mechanism that need looking at. From experience ( have repaired 100s of Me-supers ) it is likely that your shutter needs attention : rubber components ( and foam rubber ) inside the shutter ( and the mirror box locking mechanism especially ) have perished and need replacing.
Sep 21, 2007 | Pentax ME Super 35mm SLR Camera
Pentax ME SuperProgram shutter button doesn't release shutter
It is possible that the mirror is stuck in th "up" position. You should be able to fire the shutter as you say on the 125x setting with no batteries. You can download the manual from the link below: Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 26, 2007 | Pentax ME Super 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
71 people viewed this question
Top Pentax Photography Experts
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
