Question about Molten ML TIMER DIGITAL TOP70 (ML-T70) Oven
Kenmore wall oven model #8504218390
Oven making bussing sound that may be coming from the timer even when ovenis turned off.
0 characters
1 Points
When I turn on the self cleaning oven, it makes a loud buzzing noise. Is this normal? If not, what needs to be fixed and how do I do it?
The buzzing sound comes from the relays located on the control board. Remember, the oven gets very hot during self clean, so the control works at full speed to get all the elements working.
Jan 03, 2015 | Kenmore 30 in. Electric Self-Clean Single...
When I turn on the wall oven it will not heat up, the light doesn't come on
If the oven element or the indicator light don't come on it sounds like a timer problem. I assume the oven has an electronic timer/clock. The timer must be in manual mode for the oven to work. If so, turn the oven ON. Then operate the clock/timer buttons to get it in the manual mode. Be patient. When the oven indicator light comes on it is in manual mode.
Please vote for me if this helps you.
Mar 05, 2011 | Ovens
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I have a 40 year old Tappan electric wall oven. It has an analog clock with 3 timers on it (2 small timer...stop and start and a large timer with 3 hands on it). Which position do the timers need to be for...
I have one of these too. the TOP small clock should be set to the time you want the oven to start and the BOTTOM small clock should be set to the time you want it to turn off. Be sure to set the oven settings to what you want and the correct temperature.
Try testing it first just to see if it works correctly. It's also important to make sure the other large clock on the oven is set correctly.
May 01, 2010 | Ovens
278.4088891 Kenmore wall oven. The display goes black
Sounds like the "display" part of the timer is faulty or has a bad connection. As the cooker still heats up then the "relay" is working ok.
A replacement timer will be roughly £70 - £80
Hope this helps
Aardvark Repairs
Nov 15, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Put in new wall oven , turned on power and set
my kenmore double oven model 41165 has no power....its hardwired 40 stopped working when it was cooling down after the slf cleaning cycle..we had a storm and had a minute power outage. Finakky got the door open but it wont turn on at all. Tried the breakers but i stll get no even the bulb.......thanks....
Jun 07, 2009 | Ovens
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Tried to use broil or bake on my Kenmore electic oven model 40881, press broil and after a few seconds a code of F4 comes on the screen and the tone sounds, I hit cancel and tone goes off. Can't use
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Jul 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Molten ML TIMER DIGITAL TOP70 (ML-T70) Oven Logo
44 people viewed this question
Top Molten Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Molten Oven Expert? Answer questions, earn points and help others
