Question about Baby Lock Esante
My touch screen doesn't always work. Sometimes I have to touch all around the square and even then, it won't come on. At times, it stops working when I want to change patterns. It seems to work most of the time in the sewing mode, just problems when in the embroidery mode, Button response has shifted to the right about 3/8 of an inch. Previously it moved up a bit and a "servicing" corrected that, but in less than two months it's out of whack again. Help! I can't afford the shop bills.It otherwise works well.
    Guru:
  • 1,894 Answers
Your model number what company?
Posted on Dec 31, 2007
Janome Memory Craft 10000 touch screen problem
Sometimes machine screens can be re-calibrated.
Jun 27, 2013 | Janome Memory Craft 10000
My Designer 1 sewing machine touch screen is frozen and won't calibrate or respond to touching. This is intermittent behavior. Sometimes it works, and sometimes not. Can you tell me what this is
Sounds to me like the plug-in connector from the screen is not firmly attached to the motherboard (directly behind the screen but inside the machine). This kind of problem doesn't take a factory trained technician. Ask various sewing machine dealers to whom they subcontract cleaning and adjustment. Ask people who sew whether they have the name of a repair person. Taking apart the machine and replugging the connection should be all of a 15 minute job.
Feb 23, 2013 | Husqvarna Designer I
Babylock Esante stopped. Just makes loud noise but won't move even manually.
You probably have a jam. Start digging under the bobbin area.
If you get it all cleaned up under there... and it still won't move. Time for service by a pro. Could be something horrid like a bent shaft.
Good luck
Nov 03, 2012 | Baby Lock Sewing Machines
L have an Elna 1010 that has never been plugged in. Do I need to oil it before I use it? Is it ready to go after all these years?
check in the manual and see if it's self oiling or not,, some
machine parts are soaked in oil from the factory & don't need
to be oiled other machines have to be oiled,,if the manual doesn't
say then contact elna customer service and ask them.
I won't promise the machine will work or won't work if it's been
sitting for years ,sometimes the grease can become sticky and
hard.
you'll be able to tell as soon as you start sewing, make sure you
read the manual completely, that way you know what the machine
will do and what it won't do.
always use the proper needle for the fabric
and the proper foot
if you go over a seam and the machine seems to struggle, take your
foot off the foot pedal and use the handwheel to move the needle
manually over the seam, that way you don't bend a needle and cause
the machine to jump time.
also make sure to have a comfortable chair and good lighting and
a good seam ripper just in case of a mistake.
if you get frustrated while sewing, get up and walk around, that can
help clear your mind, I've had to do that plenty of times and I've
been sewing for 30 years.
if you don't have a manual send me a comment and I'll try to find you one.
there are several websites that have tutorials and other things for
a quilter,,
happy sewing
Oct 19, 2012 | Elna 2007 Mechanical Sewing Machine
My grandmother recently gave me her industrial singer 49 d200ga machine, and i love it because it works fine. However, when I brought it home, the foot pedal stopped working properly. How can i get it
Is your industrial machine one that has a big motor mounted under the table? If so make sure the power cored is plugged in. Also if your pedal is not installed properly it will sometimes flip forward get bound up and won't allow the proper throw to run the motor. Since the pedal doesn't supply power check the linkage to the motor.
Oct 03, 2012 | Sewing Machines
I have a husqvarna viking 5610 and it was an auction find. The reverse button doesn't work at all. It won't go in or anything. I've looked inside the back and it doesn't appear that...
Try setting the machine in direct sunlight with the back cover off and let it get nice and warm. It might even need a little assistance from a hair drier. Warm the area directly behind the reverse button. If you can get it to move a little, you will see which parts are moving. Use Tri-Flow on these parts and they may come loose without having to take it in for service. DO NOT USE WD-40 or 3-IN-1 oil. Go to a bicycle shop and get a small bottle of Tri-Flow liquid.If that won't work, any authorized Husqvarna Viking repair center should be able to take care of it for you. Don't force anything too hard. If you break anything, you may not be able to find parts as they are no longer available from the manufacturer.
Sep 09, 2011 | Husqvarna Viking 1
Touch screen stopped working
Have you tried to recalibrate the touch screen in the Set Menu? If so, and it still doesn't respond, then the touch screen might have gone bad. This is something you should have a dealer repair. About a $200.00 repair.
Apr 28, 2011 | Husqvarna Viking 1
I have a Janome MC9000. The touch screen is out
You need to adjust the screen. Turn the machine off. Press simultaneously the three buttons on the front (Start, reverse and stop) at the same time turn the machine on.
Press the crosses that appear on the screen and it should all be fine.
Jun 10, 2009 | Janome Memory Craft 9000 Computerized...
My touch screen doesn't always work. Sometimes I have to touch all around the square and even then, it won't come on. At times, it stops working when I want to change patterns. It seems to work most of the...
Yes, I have a solution for this problem. Your screen needs to be recalibrated and you can do it yourself. Don't you wish they would just tell you this stuff instead of charging you an arm and a leg? Here's what to do: Before turning on the machine, press the start/stop button, the reverse button, and the needle position button all at once with one hand (one finger on each button). Hold them down and turn on the machine. What will come up is a recalibration screen. You will see the numbers 1-5 with a little plus sign beside them. Find a small blunt object (I used the tip of a mechanical pencil with the lead in instead of out) and while holding the start/stop button, touch the plus sign beside 1-5 in numerical order. Then, turn the machine off and on again in the normal way. This should recalibrate the screen. Pass it along, people! This is something no one should have to pay for!
Nov 03, 2007 | Baby Lock Esante
Sewing Machines Logo
108 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
