the vinyl primer button on your carb shoots fuel into the crankshaft space. when you pull the rewind air and fuel in the crankshaft area is sucked into the combustion chamber. when the magneto reaches almost top dead center, the high voltage fires the spark plug. if there is an air leak in the gasket that surrounds the crankshaft, the air/fuel mixture will be way off. flooding will occur and the plug will get saturated. remove the whole back of your engine and clean the mating surfaces. now use high temp permatex and run a bead all around the gasket surface. tighten all the bolts - screws. push the primer button twice and try starting the engine.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Poulan P3314 14" Gas Chain Saw
my polan 14'' woodshark will not start. i changed the spark plug and ignition modual but i dont...
(More)
my polan 14'' woodshark will not start. i changed the spark plug and ignition modual but i dont seem to be getting any spark
i have already clean carb, filter, and has a new plug it will start but will not stay running. easy...
(More)
i have already clean carb, filter, and has a new plug it will start but will not stay running. easy to start first time but after that will get harder and harder
While trying to start my P3314, the pull cord got stuck while pulled out. I removed the cover. The...
(More)
While trying to start my P3314, the pull cord got stuck while pulled out. I removed the cover. The white pull wheel will not turn. I have removed the rope and the screw that apparently holds the wheel to the cover, but I can't get the wheel to come free. What's the trick?
