Question about Tvone TV-207 Television
I need to get rid of the block on my tv screen
Rectanglar block on some channels What to you need to be a valid product its a TV set
  • mmilanow Mar 30, 2009
    on some channels, a rectangular black translucent box appears in the middle of the screen.  You can see the picture on the top and sides, and if you look carefully, you can see it telegraphing behind the picture.
    When I hit the menu, I can read the menu and the box disappears.  When a change the channel, and hit exit out of the menu or channel display, the box comes back.
    It appears to be as wide as a analog signal, but not as tall.  It does not interfere with menues, or channel changing.  You just cannot watch the channels it appears on.  Seems to be on lower numbered channels.
    That had no effect.
    Problem Solver:
  • 8 Answers
Turn the text in the closed caption mode off.
Posted on Dec 31, 2007
'Black box' appears on JVC TV screen/blocks picture
Any chance of a model number to enable accurate description?
Dec 21, 2007 | Televison & Video
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
THERE IS A BLOCK BOX IN THE MIDDLE OF THE SCREEN ON ONE CHANNEL
This is a text box. To get rid of it you press the cc button. You may have to press the cc button more than once or twice in a row. There is no harm in pressing the cc button. In fact turn to that channel and press it a few times in a row while looking at your screen. You will notice that you will see cc:1/2 cc:2/2 cc:text3/4 cc:text4/4 and cc:off
or something like that. When it says cc:off you will no longer see the block box on this channel or any other channel. You do not have to do this for every channel once it is done.
However the text box might be set on the caption setting in the cable box or satellite tv box. If so the procedure is different.
Mar 20, 2010 | Sharp LC-19SB25U 19 in. LCD HDTV
I have a FISHER TV
when press menu go to setting channel and setting back all channel from no 1 to..... ok
Jun 06, 2009 | Fisher PC-25R20 25" TV
Black rectanglar spot
Make sure the text box function of the closed captioning is turned off.
Aug 31, 2008 | Sansui DTV1900 TV
Locked tv
The Digital Channels are Blocked and Some of the Annalog Channels are Blocked that you can't access some channels and how do you unblock the channels by getting rid of the Code for Parental control?How Do you get rid of the Parental Code to acess all Channels .
May 27, 2008 | Apex Digital GT2011S 20" TV
HOW CAN I GET PROTECTED PROGRAM TV-PG OFF MY TV?
This problem is caused by your TV's V-chip setting.
To fix the problem:
Push the "Menu" button (on either the remote or the TV's fromt panel).
Use the "Channel Down" button to go to "V-CHIP SETUP"
Use the "Volume Up" button to select it.
In the V-chip setup screen, the rating that is selected by the user as viewable will allow that rating and only lower ratings to be viewed on that TV. (If TV-G) is selected, then any programs rated higher than TV-G will be blocked.
So, the easistway to get rid of any blocking is to set the rating to TV-MA (mature), and then any and all programs will be viewable on that set. Select "TV-MA" by hitting the "Volume Up" button after you have scrolled down to that rating with the "Channel Down" button.
Then hit "Menu" to exit out of the settings and saave your changes.
Jan 27, 2008 | Sylvania 6432TE 32" TV
32 inch sylvania tv
To fix the problem:
Nov 23, 2007 | Sylvania 6432TE 32" TV
Televison & Video Logo
79 people viewed this question
Top Tvone Televison & Video Experts
Jaime Hernandez
Falling star
Jeffrey
Jeffrey
Are you a Tvone Televison and Video Expert? Answer questions, earn points and help others
