Question about Bose Lifestyle 38 DVD Home Entertainment System System
Life style error codes 801 & 802
I Have problem with stored cd,s displays code errors 801 & 802
I just installed in my system bose the lifestyle VS-2 works well but I appear on the screen of the system error 802 and 801
  • 3 more comments
  • cedarmartin Feb 03, 2008
    I recently had the same error codes (801 & 802) show up on my Lifestyle 38. So far it still works but it's making lots of noise. Called Bose and for $165 I can get it fixed. A friend told me that maybe I could just clone the hard drive in the media center. Could this be a valid option?
  • Anonymous Mar 04, 2008
    I had the same problem but the person-in-chg mentioned it takes 2weeks to fix the problem, really?
  • Anonymous Jun 04, 2008
    I had the same problem as well. Bose initially informed my that it would also be about $165 to service the media center (since out of warranty). The real problem stems from the last umusic software update that was sent out in January of this year. Some of the updates sent out were corrupted, as a result, your media center makes a loud whirring noise. If you inform Bose that it started this issue right after installing the latest software update, they may consider swapping out the unit for free. Worked for me.
  • tshaf03 Jun 27, 2008
    I installed UMusic update MD 01.01.16 (2008 March) which was mailed to me this week (week of June 23, 2008). After installing the update, I had the same errors - 801 and 802 with the media unit screeching.
    I called technical support, they were very professional. After some initial questions, they were going to replace the unit at no cost to me. What extraordinary customer service!! An English speaking, very professional support rep - no arguements, no escalation to a supervisor, no pain at all. It's rare a company stands by its products like this (after warranty was expired - My Lifestyle is 3 years old).
  • vemil71 Feb 09, 2009
    I have the same problem with my Lifestyle 38 unit, unfortunately I live in Eastern Europe (Romania) and the Bose dealer ask me to pay almost a $1,000to have the unit replace and I think is way to much.
    Can you give me some advise please at vemil71@gmail.com
Hi, I had the same problem, they had to replace my harddrive and the dvd, lost all my music, 145 cds, just got it back, it now works fine,
good luck
jps
Posted on Jan 18, 2008
Unfortunately my Lifestyle is dead after getting these errors!
Bose will fix it - replace it if necessary - but at a cost!!!
Posted on Mar 18, 2008
VS 2 not found
Try unplugging both the main console (lifestyle) as well as the power to the vs-2. (IT's the black cord). You have to wait 30 - 60s. This worked for me after also making sure the video was set to "NTSC Progressive" (you can do that by turning the bose off, holding down enter, and then pressing store twice till you get to "video". Then use the volume arrows to select NTSC Progressive.)
Nov 16, 2009 | Bose Lifestyle 48 System
Same problem LS 38< two years, error 802, unplug and erase umusic
Sounds like hard drive is failing, 802 and 801 is hard drive problem. i have same problem. only fixable by bose repair man... tryed to change hard drive myself, changed over, looks same as playing but no sound. hope this helps:) common problem with bose other than that i have had not other probs.
Jul 10, 2009 | Bose Lifestyle 48 System
Error code 10 during sound calibration
Please ensure that you have turned on the Accoustimass module, this can cause communication errors when calibrating. Also check that all connections are correctly plugged in as if one is not quite sat right this may give the error, just try unplugging them and plug them back in.
May 31, 2009 | Bose Lifestyle 35 Series II System
Bose lifestyle fault code 802 hi there- i have a bose lifestyle 48 and on display it reads format unsupported when i try to listen to cd's gut not on dvd's - in addition i am unable to store music into the...
Unfortunately, an 802 error is bad. That means hard drive (HDD) failure. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home.
If you even try to troubleshoot it (reset etc), you could loose more data (music you've already stored to the system). If you try to access 'stored' music- the error will continue. Also, every time you turn the system off, it checks your HDD, and will probably cause the 802 or 801 errors to display again.
The "Format Unsupported" message may be related, but usually temporary. The 802 (and also 801) errors mean irreversible HDD damage so it doesn't matter.
Call Bose tech support immediately.. They can repair it for $165 and give a new 1 year warranty. And if it's already under warranty they will repair for free. In either case they will replace your HDD with a new one, and transfer any salvaged music files from your existing drive to the new drive.
May 31, 2009 | Bose Lifestyle 48 System
Here's what the Bose support website suggests.  Good Luck!
Messages displayed during a Music Information Update
Messages may appear on your media center display during a Music Information Update. If you see a message with instructions to call Bose, and a three-digit code such as "Error Code 802" or "Failed 172" while performing a Music Information Update, it does not necessarily mean there's something wrong with the system. Performing a media center reset and installing the update again may address the issue.
To reset your media center, follow these steps:
  1. Turn the media center off. Wait two minutes
  2. Unplug the power cord from the media center. Wait 30 seconds
  3. Reconnect the power cord
  4. Wait until "Bose Lifestyle" disappears from the screen
Note: After a reset, you will need to wait several minutes before playing stored music (3 to 20 minutes, depending on how many CDs have been stored). All other sources will be available immediately after the system powers up.
If you have any additional questions about these messages, please contactBose® Technical Support or call 1-800-278-1281.
Dec 01, 2008 | Audio Players & Recorders
System does not work
try update cd,,,, i might work..
if its hard drive normally says error code, might be somthing like mother board...
Sep 22, 2008 | BOSE48 - Lifestyle 48 Home Entertainment...
Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
Jan 26, 2008 | Bose Lifestyle 48 System
When being in contact with BOSE support i got the message that "FAILED 802 Call Bose" refers to issues with the harddisk not being identified.
In my case I had to send the unit to BOSE support. I replaced the existing disk with an identical unformated one but some more actions are needed. The question is what .......
Nov 18, 2007 | Bose Lifestyle 48 System
Bose Lifestyle 48 Error code 801
We had this problem. I called Bose, and they reported that the 801 error is a hard drive problem. The unit started squealing while I was on the phone to support, and the guy heard it. Said the hard drive was failing.
$200 to ship the unit to Bose to replace the drive. Wish they had a secret warantee for what seems like a common problem.
Oct 01, 2007 | Bose Lifestyle 48 System
Bose Lifestyle 38 DVD Home Entertainment System System Logo
3,528 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
