Question about Vacuums
Check the sheer pin on the auger assembly. Could also be the belt needs adjustment or replacement
Posted on Jan 03, 2008
Delta 36-600 table saw new belt run's and sounds great, BUT wont cut butter?? Any help would be great thanks. Oh could it be brushes?? Cheers Matt Blade is in the right way,Delta 36600 have brushes.
Not to insult your intelligence, check the blade direction. Looking at the tablesaw from the left side, the blade should be turning clockwise and the teeth cutting downward. Also the teeth should be very sharp. Typically a belt run tablesaw doesn't use brushes but a capacitor to start rotation. You didn't mention if the blade turns when started. Since you mentioned it sounds good when started I'd rule out the motor. Some saw blades have an arrow to indicate direction. Hope this helps. Good luck.
Oct 28, 2017 | Vacuums
How To Change The Fan or Impeller Blade On a Kirby Generation Vacuum
Below we have shot a video on how to replace the fan blade (also known as the Impeller Blade) on a Kirby Generation 4 Upright Vacuum Cleaner step by step in an easy to understand format. If you'd like to see a repair done by video, please contact us. Also be sure to stop by our website for all of your Kirby Vacuuming needs;
Part 1
Part 2:
If you found this repair video helpful, please be sure to rate the repair as helpful by clicking the Thumb Up Icon at the bottom of the repair page. Feel free to contact me if you have questions on how to do it, or how to purchase the part.
Thank you,
Chris J.
on Mar 20, 2010 | Kirby G4 Bagged Upright Vacuum
Why is suction substantially reduced?
blockage in the suction line
if it is the wet mode there should be a valve (ball) that sucks up to stop water from getting to the motor when the receiver is too full. If you are in wet mode and still have the dust bag in place then the bag will be a solid block of mud and that will be the blockage.
May 21, 2015 | Craftsman 17765 Canister Wet/Dry Vacuum
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
The piece under the blades cracked can it be replaced with out buying the whol blender
You can try removing the blades and put apoxy in the crack and let it dry. Put the blade back on and make sure the blade does not rub by turning the blade by hand to see if it turns smoothly. Do all of this while the blender is unplugged.
Mar 11, 2011 | Vacuums
have a look at the brushes are they turning and if they are can you stop them turning if you tuch them with your hand??? if you can stop them turning the brush drive belt is slipping get a new belt and fit it,,
problem sorted!!!!
Jun 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I was blowing snow with my Toro Power Curve 1800. I was distracted for a moment and tangled the cord in the blade. The cord is wraped around tight, how can I remove the cord?
unless you are able to turn the blade backward and pull on the cord at the same time no luck. it may be easier to just cut the cord and install a new one. solution one is best and both require taking the machine apart. start there and hope it works out for you.
Ps. dont forget to rate the solution. Thanks
Dec 28, 2008 | Vacuums
Craftsman table saw
Alright, I have fixed mine, so maybe the same thing will work for two as well. I actually have a slightly different model (113.298341) but I imagine the electronics follow the same basic layout. FYI, I got a manual online through Sears for free.
Mine has a manual reset thermal overload protector to keep from burning up the more expensive stuff. It is the red "reset" button near the main switch that ought to pop out if it gets too hot, and can only be pushed back in when the machine is back down to a safe operating temp. I overloaded my machine, and the protector broke the circuit, BUT the button did not pop out and I therefore couldn't just push it back in. I took out the protector, and although it looked like the circuit should be closed, there was no conductance through the protector. I took off the tiny bolt on the back of the protector, essentially jostled the thing a little, replaced the bolt, and conductance is now restored. I re-installed the protector, replaced the front cover, and now she works like a charm.
So maybe these reset switches often don't act like they are supposed to? I'd recommend just checking everything in the line, beginning with the main power line in. it will contain three wires: the ground will be bolted to the frame, the others will run to the main switch and the relay, respectively. With the machine plugged in, touch your volt meter probes to the contacts on the way INTO the switch and relay, and you should have 120V. Then, check the switch by turning it to the ON position with the machine plugged in, leaving one probe on the IN contact of the relay, and moving the other to the OUT contact of the switch. Again, you'll get 120V if the switch is working correctly. Alternatively, you could just check conductance through the switch directly w/o involving the relay contact, either way is fine.
Next in line is the thermal switch, which was my issue. Unplug the machine and/or turn off the main switch (I do both, no point taking risks). You'll need to unscrew the switch, which is a black plastic cylinder about an inch in diameter with the red reset button on it, and check for conductance by probing the wires leading into and out of the back of the black plastic cylinder. If you don't get conductance, you're in the same boat as me, and try to fiddle with the bolt and restore conductance. Otherwise, it might be the relay or the capacitor on down the line. If not those, your motor might be shot, but we'll hope thats not the ca$e.
Hope this helps guys, I was really surprised that it turned out to be such an easy fix, you just need a screwdriver, a 3/16 wrench (for the bolt on the switch), and a voltmeter that tests up to 120V and can test for conductance. One thing to be very careful of is the large capacitor in the control box. I just stayed away from it, but I would seek further advice on how to test it if you need to. After taking apart a couple of cameras as a kid, I know not to mess around with those things. Otherwise, just use the same good sense you should bring to any fix involving 120V of electricity and a 10 inch steel blade.
Aug 12, 2008 | Craftsman 17026 Wet/Dry Vacuum
Vacuums Logo
43 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
