Need to convert from propane to natural gas on jenn-air jds9860aap
SOURCE: Why does the range give us a caution that the range has been setup for propane.
stove comes from the factory set for natural gas, be sure your not reading a sticker that would affix to the range after you convert it
SOURCE: Converting a range from LP to Natural gas
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
SOURCE: Jenn Air cooktop JGD8130ADS - Propane to Natural Gas
propane has more BTU, so has a small hole, NG has a laeger hole, when i last called a plumber, all he did was remove them and drill a larger hole...i don't know what the hole size was, but thats what he did. hope this helps
SOURCE: Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Your
problem could be or probably is with the regulator...not enough gas
pressure...
Propane,
LP, or Natural Gas Regulator Problems
heatman101
