Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
ERD30 will not reach or maintane setpoint
Dacor Model ERD30:
When using bake function, after you set temp the unit will sometimes count back from the setpoint 10-15 degrees and will never reach the intended setpoint. Or sometimes you can set the bake temp and it will function normal, but never reaches it's setpoint.
Could this be a defective oven temp sensor?
What is my best available source for replacement parts online for my
Dacor ERD30?
Thanks to everyone in advance for your help!
Sell the piece of junk as fast as you can and go to Sears and buy a Kenmore.
Posted on Aug 01, 2008
    Genius:
  • 1,665 Answers
    President:
  • 1,314 Answers
Read your owners manuel and follow the instructions for adjusting the oven temp set it 15 degrees higher
Posted on Dec 31, 2007
A fan runs constantly when my Dacor ERD30 oven is in bake mode. Is this normal?
yes the cooloing fan runs when oven is turned on and should be set to continue running after oven is turned off
it should be set to run until oven drops below 300 deg f
this can be changed if not set correct
Sep 17, 2018 | Dacor Kitchen Ranges
Temperature fluctuates in bake setting. Temp on display does not match real oven temperature.
as long as your measured temperature is within 15-25 degrees of shown temp, then it should be ok. remember the temp in the oven will be different from top to bottom.
Dec 11, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
I have a dual fuel Dacor ERD30 range that will not stay hot. Lately, it will heat up to the desired temperature and beep to indicate it is ready, but then will not hold the temperature. And strangely, if...
Sounds similar to what mine is doing.
Since Dacor uses the gas broiler to preheat the oven, the problem is that the lower heating element isn't getting power.
I took out the element and verified that the element is still good, but no AC voltage coming from the relay board to the element.
Try setting on the Pure Convection mode - it will probably heat up and hold the temp fairly well - that still doesn't do any good if you need to bake something covered (convection modes are useless for covered container..
Mar 28, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
My dacor oven model ECS130SBK is very slow to heat. Sometimes reaching the desired temp. after a long wait. Sometimes it never gets there.
I found the bottom element was not getting any power by using a volt/ohmmeter and a test method described elsewhere. (Shut off power, hold down COOK TIME while turning on power. then within 30 seconds press each mode you want to test and only that element/fan/etc will turn on. Cancels by itself after 30 sec.)
I traced the wire back to the relay (wire checked good) and there was no power getting through the relay although it clicked. Removed the relay board to replace it and found a cold solder joint on the "out" terminal with obvious past arcing carbon. Cleaned and soldered the pin and the oven now works normally.
WHY THE SLOW TO HEAT? The oven turns on all the elements to preheat faster and when it reaches your set temp it beeps and now only turns on the element you selected to maintain the temperature. (Bake or Convection) Our malfunctioning ovens would then cool since the element is not working properly and it must go back into preheat and keep cycling.
BY THE WAY- Don't ever use 4 hours on self clean it kills the boards and/or display. I also put a house fan in front of the oven and blow it into the lower grill to take away some of the heat on the two boards. Learned the hard way!
Jun 08, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven will not hold a constant temp.
a faulty bake ignitor would not allow the unit to maintan temp , very common issue with all gas ranges
Nov 20, 2008 | Kitchen Ranges
Dacor ERD30 oven trouble
HI,
Check if both circuit breakers for the oven are on.
The control board needs only 120V but it should be 240V for the heating elements to function properly.
Check if there is 120V coming to the thermal fuse.
when you get your meter . put the oven on bake and check your power on the bake element if you do not have 240 volts then your control board is bad. if you have 240 volts then you element is bad.
Goodluck,
Please don't forget to rate the solution.
Mar 25, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
392 people viewed this question
Top Dacor Kitchen Ranges Experts
Oloyede Monsuru
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
