Question about InFocus ScreenPlay 4805 Multimedia Projector
Fan does not operate
After cleaning the bulb screens and re-inserting the bulb housing on my SP4805, the fan that cools the bulb does not run and the projector gets very hot. Also, it makes some occasional whirring sounds. The projector operates normally with a solid green LED. Any ideas?
  • 2 more comments
  • Doc E Jan 06, 2008
    As it turns out, the fan does seem to be obstructed. The fan blade rubs against the plastic surrounding it which prevents it from turning. Not sure how that happened. Seems like I need to get inside it to fix it, but had a little trouble figuring out how to open the machine. Any guidance on how to open the 4805?? Thanks!
  • Doc E Jan 09, 2008
    Thanks for the great instructions for taking the cover off! I managed to get the projector open and apart without much trouble at all. I managed to get the fan out of the projector and it seems to me that it needs to be replaced. Having trouble finding a Nidec BETA SL model #D08G-12TS4 fan online for replacement. Anyone know where to get one or a compatible replacement? Thanks again.
  • Doc E Jan 15, 2008
    Well, found a replacement fan and installed it. However, after putting everything back together, the new fan does not operate either. Does this definitely indicate a problem with the board?? What are my options now?
  • Ken L Jan 23, 2008
    I am having the exact same problem with the same Nidec Fan.
    Doc E, where did you find a 12 Volt fan that will fit in this system? I have found 12V fans but nothing that will fit. If/when I find a fan and still have the same problem I was thinking of hard wiring something externaly to see if the issue is the fan, the fan electrical port, or the board.
    I took my projector into a repair shop and they charged me $100 to tell me the fan was broken which I already knew. They stated that they could not fix it either.
Glad to have been of help with the instructions. Don't bother of getting the exact replica of the fan just get the right size that fits they are usually all 12volts and shouldn't be a problem to find.
Posted on Jan 09, 2008
Turn the projector on it's back unscrew the 4 screws that are on the front and back grill. Unscrew the 4 screws that hold the bottom case. remove the 3 small screws from the back grill. Remove the focus and zoom rings. The zoom ring can be stubborn to remove. What I do is lever it off by pulling the front grill. Don't try to remove the front and back grill from the top case. It's better to remove them together. When you succeed in removing the zoom ring, lift the the front grill together with the top case up. You should be able to insert your hand to push off the keypad and speaker plugs. When you're reassembling back the covers, separate them by gently prising the front and back grill from the top cover with a flat blade screw driver from the inside. Assemble the top cover first and not forgetting to plug in the keypad and speaker plugs at the back.
Posted on Jan 06, 2008
Make sure that nothing is obstructing the fan. Try to rotate the fan with your fingers to make sure it is free. If it is, you would be lucky if the fan is at fault because this is rather cheap and easy to find if not it is the main board which is at fault.
Posted on Dec 31, 2007
When its turned on blinks red about every 2 seconds dark screen
It is probably the projector bulb. The two red blinking lights indicate bulb failure. Replace the bulb and also thoroughly clean the cooling fan and vents to prevent future overheating which can shorten bulb life.
Hope this helps.
Bob
Oct 02, 2015 | Office Equipment & Supplies
Nec VT 670 It overheats after 30 minutes of use. This is when the fan is on auto. Appears to be OK on man full fan speed. The room temperature is OK and the bulb life has 96% left. Any solutions. The...
hi,
Check the lamp cooling fan of your projector one more time. may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Mar 27, 2011 | NEC VT670 LCD Projector
When we turn the projector on it gets hot then it shuts off.
check that fans are running and screens/ filters for fans are clean and free of debris
also what are hours on bulb - if bulb is too old that could be causing issues also
Mar 21, 2011 | HP VP6310 Multimedia Projector
Projector heating up and bulb shuts down
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 08, 2010 | Dell 2300MP Multimedia Projector
How do i find out if i need a new lamp for my infocus 4805. when i turn it on the fan blows for a cpl secs and the green light blinks a few times, but i dont get anything saying the lampis out
when you power it on, do you hear a high-pitched whir? if not, you need to replace the colorwheel. it's also the colorwheel if you hear a buzzing instead. if the colorwheel does not spin, the lamp won't come on. if the colorwheel is ok, check the lamp. is the screen on the side of the lamp clogged with dust? is the inside of the lamp bulging, spotted, or foggy? if so, replace the lamp and clean out your projector with canned air. dust blocks air flow and keeps in the heat. this shortens the life of your lamp and projector. if you do need the colorwheel replaced, you could get the part from an infocus service center and do it yourself, or send it in for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 27, 2009 | InFocus ScreenPlay 4805 Multimedia...
It makes a wierd noise
The bulb housing has come loose...
When the bulb heats up & cools in normal use, the housing will contract and become loose.
Unplug and re-seat the bulb and housing ...
Another possibility: If the replaced bulb shattered in the projector, there may be debris in the fan... use compressed air ($8/can RadioShack) to clean out (make sure the projector / bulb are cool before using compressed air.
Hope this helps!
Sep 09, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have SP4805 bulb does not fire up "New"
push and hold both volume up and volume down for 10 seconds.
Mar 03, 2009 | InFocus ScreenPlay 4805 Multimedia...
SP4805 bulb does not fire up; led stays green; fan turned on
I had the same problem after purchasing a new bulb. My husband pulled it out after it would not fire up and the new bulb plug in conecter (white with 4 holes with two wires) was different. Take your old bulb and compair the two conecters and see if they match, then check if the wires are in the same slots as in first and last. Mine on the new one were in the first and second to last slot. So we took the wire out of the second to last and put it in the last slot and installed it and it fixed the problem. We also had to unplug and replug it in and do a master reset by pressing the Power and Channel buttons and the same time for 15sec. Hope this helps.
Jan 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
SP4805 Fan Issue
the fans in these models do not have a speed sensor wire to let the main board know to turn off the lamp to not risk overheating. so if the fan goes, the lamp remains on. however, if the lamp exploded, check the vents for dust. there is a temp sensor that will shut down the projector if it gets too hot. if the vents are clogged, blow the dust out of the projector with canned air. the dust keeps in the heat that the projector is trying to expell. easiest way to repair the fan w/o buying a part: splice the fan wires together. they can share voltage. if the 80mm fan does not work at all after that, replace the fan (pn: 526-0192-xx).
Jul 31, 2008 | InFocus ScreenPlay 4805 Multimedia...
SP4805 - Problems after Fixing Fan
Hi daveyboy84
Take out all the connections one by one and check the pins on the inside.
May 22, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
1,117 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
