Question about JVC KD-G430 CD Player
Unit was super hot...
Installed it two days later noticed the unit was HOT!!!!
  • medicbear Dec 31, 2007
    hot while playing... like way hotter than i have ever exp. even in the summer
  • 36 Answers
Hot while playing, or while turned off??
Posted on Dec 31, 2007
Ok so I have a ge cafe. I recently replaced the motherboard as my controls were all messed up and it was not cooling. Afterwards it worked fine except that there was a howling noise inside of the unit. A...
Correct, condenser coils remove heat from the freezer compartment, thusly they will be hot. Sounds like the compressor is failing and that is probably giving off a squealing sound and stops running until it stops. Then your compressor will overheat and stop running until the thermal protector cools down and allows it to run again. Try replacing the compressor cooling fan.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 15, 2017 | GE Refrigerators
I have a saeco super automatica Leaking water
Take the brew unit out when the machine is off and cold. With your finger, check the well next to the large gear on the inside of the machine. This is the gear that fits in the back of the brew unit when it is in place. That well may be clogged with fine coffee grounds and some mildew build up. You might notice that after brewing, very little water will has been flowing into the drip tray. Take a Q-tip and push it through the hole at the bottom of the well to remove the coffee ground buildup. The excess water after brewing will flow through normally now and not behind the brew unit.
Mar 02, 2017 | Saeco Coffee Makers & Espresso Machines
Readout says "HOT". fan stays on. Unit is not hot. Disconnected fan to save battery days later reconnected and still same. Is there a bad sending unit or T-Stat?
On a 2004 Sportsman 400 there is a sensor on the left side of the engine head, just under the thermostat housing. If that sensor is bad or disconnected the hot lamp will come on which causes the fan to constantly run. Good luck and if you need any more assistance let me know, Daniel.
Oct 27, 2012 | Polaris ATV
Kenmore elite side by side w/ middle divider super hot
absolutely not
that middle peice should be hot to the touch
this is the mullion heater or yoda loop in the old days
this is what controls moisture from entering the unit
when you open the dooor
mine has been running for 7 years no worries
Oct 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The center divider (between the doors) gets so hot you can't touch it. Other than that- it works and cools just fine.
ok that is entirely normal
that is your moulion heater, it is ment for two things
a. it keeps your seals soft and plyable
and b. it controls hot air entry to the unit when you open the door
it offsets the heat barrier with the door open,
that is what stops humidity from building up oin the machine
Oct 16, 2009 | Samsung RS2630WW Side by Side Refrigerator
Intermittent A/C outage
your climate control unit is bad you can get a used one from the salvage yard it should work fine
Aug 18, 2009 | 2001 Chrysler Sebring
The center area of my Kenmore 59282990 is very hot. The ice maker is working fine. I unplugged the unit for 3 minutes and plugged it back in and the unit cooled off in the middle then about 20 minutes...
The heat in the center of the doors is normal and can reach 120 degrees to reduce condensation. There used to be a energy saver switch installed to turn off/on the heater. They no longer use energy saver switches to save about 50 cents a month on utility bills. They use other energy saver parts that are not user controllable to save the 50 cents.
Aug 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Wine fridge not cooling
It is normal for a compressor to be hot to the touch, but not super hot. clicking noise sounds like the relay located on the compressor terminals is bad. Hope this helps
Jul 27, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Bad smell from ac unit in my house
does it smell like literally , dirty socks?if so it is dirty sock syndrome, a plague of heat pumps for years. if it smells like an electrical melting or burning of wires then time to call a pro.it could be a weak capacitor or a weak fan motor. if it is dirty sock syndrome then its the microbes that thrive when temps are middle temps and reproduce when temps are hot and cold in intermittent days. hot one day and cold the next equals call for cool then call for heat and hot steam from heated coils cause s bacteria to grow and microbes to spread across coil. when you switch back it causes the smell.if the coil is clean you can spend a chunk of money on sanitizers but best bet is to run it cool for hot weather and hot for cool weather. the transitional periods are what create the smell. avoid semi cool and semi hot periods. this condition is common to acs from all brands . lots of stuff on the internet about dirty sock syndrome
Oct 31, 2008 | Sharp CV-P09FX Air Conditioner
Oven wont turn off
Turn off the power to the range and contact an authorized technician.You may have a fire producing issue.that needs immediate attention!
Nov 21, 2017 | Kenmore 92002 / 92004 Kitchen Range
JVC KD-G430 CD Player Logo
46 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
