-   Last time I found a solution on the net that said push and hold a combination of buttons for 10 seconds. I just don't remember the combo of buttons, it was like the stop, record and play ones all at the same time. The 5 second stop button hold doesn't work for me. So, anyone?
-   heavenlyhone
Jul 20, 2008
-   Followed the instruction booklet to hit the stop button than hit the stop button again for 5 seconds to get the scan turned off. Nothing happens???? No picture just the words on the TV screen Progressive scan. need help please-   6152
Thanks for the progressive scan advice. I have a Go-Video DV1130 Combo I didnt have a DVD in the combo and I pressed and held the stop button on the combo instead of the remote and it came out of the progressive scan mode so maybe it works both ways? But anyway Thanks for the advice it sure helped me.
DVD starts and about a minute or two the picture freezes and you can't even eject the disc. Tried to...
(More)
DVD starts and about a minute or two the picture freezes and you can't even eject the disc. Tried to get dvd out after I unplug the player and it resets itself.
dvd player freezes and stops working I have to unplug and hope it resets. tried to clean player with...
(More)
dvd player freezes and stops working I have to unplug and hope it resets. tried to clean player with dvd Dr laser lens cleaner, but I have same freezing of dvd
How do I do the reverse? I want to copy a VHS tape to DVD. Also, can I do this w/o connecting to a...
(More)
How do I do the reverse? I want to copy a VHS tape to DVD. Also, can I do this w/o connecting to a TV? Thank you for your attention to this!
Recently had Charter Communications install digital cable now DVD or VCR will not work - cable...
(More)
Recently had Charter Communications install digital cable now DVD or VCR will not work - cable company said that my machine may need to be reset??? Machine will come on, I hit play, disc and/or tape is playing but not on the TV.
You can no longer set up a timed recording to the VCR after the digital conversion that took place...
(More)
You can no longer set up a timed recording to the VCR after the digital conversion that took place on June 12, 2009. After I ran the channel reprogram the system does not recognize any of the digital channels. There doesn't seem to be any way to get to the ??.001 identity numbers associated with the digital channels over the air. Curt
