Question about Summit Commercial 500SS Draft Beer Refrigerator/Dispenser - Kegerator "Complete"
Does anyone know anything about kegerators?
I have hooked up the kegerator properly, so I think. I checked the pressure and temp and all I get is spitting and spattering of foam. Can someone help please???
    President:
  • 1,314 Answers
First send it to me with a full keg so i can check it out what make and model is it and how are you pressuring have you checked the pressure gauge to see what happens when you open the tap
Posted on Dec 31, 2007
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
Replacing true kegerator parts
no use a Ranco p# A12-700 make sure the capillary is in the coilto sense the temp and set it to 1.5 on the knob. any colder and it could get too cold . you may be able to set it at 2 but be careful. it is a constant cut in at 37 degrees coil temp. the box temp will drop to usually to 28 or 29 at cut out.
Dec 31, 2012 | True Direct Draw Systems: Kegerator...
TDD 2 Kegerator clicking and not cooling?
It's extremely rare that the compressor will be any good. Usually replacing the start relay does nothing on these small units. If you know how to use a multi-meter and are any good at wiring the cheapest way to go is to get what is called a 3-in-1 start kit at a HVAC wholesaler. You need to know the model of the compressor and/or the horsepower to get the right one. I would recommend getting a service tech to look it over though. Most likely the compressor is locked up.
Nov 16, 2012 | True Direct Draw Systems: Kegerator TDD-2
Kegerator is pouring all foam
Try rinsing all that foam out, dry it out with hair dryer and begin again AFTER reading the WHOLE operators manual. No one ever reads the instructions. If all else fails you may have to exchange or replace the unit.
Sep 03, 2012 | Haier SS Half Kegerator
Kegerator is flashing "EE" and
I bought a new kegerator and the same thing happened right out of the box.
The display was not pluged in.take Take screws off top and check to see if it pluged in.
Nov 18, 2010 | Danby DKC645BLS Compact Beverage Cooler
Bought a used danby DKC645BLS kegerator it is missing the co2 tank bracket that mounts on the back of the kegerator, where can I find one. Also the psi is set at 10 on the co2 tank and the beer comes out...
mark pasieka has an inventory of refridgeration, kegerator and bar related parts (as well as everything else)... he has this bracket in his warehouse right now... at least one... he also has tanks of CO2, oxygen acetalyne anything you may need... mark.pasieka@gmail.com
Oct 06, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Summit Commercial 500SS Draft Beer Refrigerator/Dispenser - Kegerator "Complete" Logo
282 people viewed this question
Top Summit Commercial Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
christian nielsen
jasbo
jasbo
Are you a Summit Commercial Refrigerator Expert? Answer questions, earn points and help others
