Rear projection TV - convergence issue
Our 5 year old Samsung 65" rear projection TV (Model #HCN653WX) is having a convergence issue in the top-middle and bottom-middle of the screen, which makes the picture look concave into the tv set. A month ago, we had a Pro Scan Module replaced to fix an issue with black shadow lines appearing everywhere, which made the quality of the picture like new. We turned it on one morning and the problem appeared. I tried the 'perfect focus' option. I also tried manually correcting the convergence with the remote and also via the service/factory settings. It won't let me adjust the individual points on the screen. Any suggestions on what the root problem may be? I attached a picture of the TV and the convergence problem.
techman
  • 3130 Answers
SOURCE: "Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Posted on Nov 09, 2007
  • 1030 Answers
SOURCE: Color Convergence
you will have to go into what is known as service mode... have to have a code to get into it
Posted on Jan 18, 2008
experttv
  • 203 Answers
SOURCE: concave comvergence problem i believe
Unless you can solder and use a meter then yes you need to call a tech, this repair should run somewhere from $300-$500. Let me know if you need more info
Tim
Posted on Sep 11, 2008
SD Tech
  • 14553 Answers
SOURCE: the colors are blurry and will not converge
This model uses a Single convergence IC---a STK-393-110.
If convergence is skewed and will not adjust the chip needs to be replaced.
Most shops get 300 or more for this repair---you can buy the IC on Ebay for about 12 dollars--total parts cost should be under 30 dollars.
I have Start to finish, step by step instructions for this repair in this set--they tell you everything you will need and how to do the repair.
Let me know if you have questions or want the instructions.
If this helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 19, 2009
  • 69 Answers
SOURCE: Sony rear projection widescreen TV. Concave shapes & ghosting
sound like the convergence ics have failed
Posted on Feb 07, 2010
LINEARITY CORRECTION ISSUE
convergence problem, common on rear PTV.
This is a excellent TV. Worth repairing it.
Jun 01, 2010 | Sony Grand WEGA KDP-65WS550 65" Rear...
String Art 2
It is failure of convergence out ICs and subject part needs to be replaced, TV has 2 ICs and both will be replaced.
If you are tech person or know TV repair, let me know to provide you more info or call local TV tech to fix it.
Feb 14, 2009 | Sony KP-65WS500 65" Rear Projection...
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
Samsung HCN653WX has wavy lines and red and blue ghosting
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2008 | Samsung HCN653W 65" Rear Projection...
Please advise if you would be able to guide me as to where i could purchase tv parts...
Hello MMJB,
Here are the link to purchase your parts.
674e151.gifhttp://www.partstore.com/Part/MCM+Electronics/MCM/LA7845/New.aspx
183b00b.jpghttp://www.partstore.com/Part/Matsushita/JVC/TDA6111Q/New.aspx
4509847.jpghttp://www.partstore.com/Part/Samsung/Samsung/HCN653WX/Samsung/Samsung/0502001230/New.aspx
Best regards
circuitcity
Jul 09, 2008 | Samsung HCN653W 65" Rear Projection...
Blue Convergence
Hello All Above,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Mar 11, 2008 | Samsung HCN653W 65" Rear Projection...
65 Toshiba picture sides are bowing in.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 21, 2008 | Toshiba 65HDX82 65" Rear Projection...
Mixed colors and separation of colors
Common problem known as convergence. The most common reason is the failure of convergence ics. these ics fail all the time because there big and get fairly hot. there is a possiblity that it can be reconverged if the convergence cuircit is not damaged
Jan 05, 2008 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
253 people viewed this question
Top Televison & Video Experts
