Problem for Samsung Microphones
Generic problem for all Samsung Microphones
I have samsung sgh-d600 mic pads des...
i have samsung sgh-d600 mic pads destroy. whre i put jumper to this problem. give me solution pls,thank
Questions and Unsolved Problems for Microphones
my mircrophone is switched to the stereo option, and also selected on the software (reaper) that i...
(More)
my mircrophone is switched to the stereo option, and also selected on the software (reaper) that i am using, it is only recording in one channel. when i switch the software to mono i get both channels showing, then when i add the backing track(which is automatically in stereo) my voice recording switches to one channel only the microphone is brand new. so is it very possible the microphone is broken
HOw do you plug the Samson M15 into a stereo? Or do you need an amplifier?
I have a Magic Sing ED18000. I haven't use the unit in more than 5 mos. We try to use it last night,...
(More)
I have a Magic Sing ED18000. I haven't use the unit in more than 5 mos. We try to use it last night, the Mic went ON and functioning properly but when I'm about to use the remote, the remote control doesn't work. I tried putting new batteries on the remote but still doesn't work even pressing the ON/OFF there is no response on the unit. So what I did is I pressed the ON/OFF switch of the base manually to turn it OFF while the MIC is ON, then I pressed the ON/OFF switch of the base again to turn it ON again. After this the remote control works but the big problem is the MIC doesn't turn ON this time, I tried putting new batteries and turning ON/OFF the base manually but the MIC still don't want to turn ON. Can you help me solve this problem.
i have a fast track m-audio recorder and a philips microphone but i don't know how to connect it to...
(More)
i have a fast track m-audio recorder and a philips microphone but i don't know how to connect it to an xlr cable or even if you can. all i know is that i need some type of xlr cable in order for me to record vocals on it.
The game does not even register that the microphone is plugged in.
