Question about Mitsubishi WS-55511 55" Rear Projection Television
Three color dots
I have a Mitsubishi WS-55511 television and every time I turn it on there are three small color dots in the center of the screen. I assume this means the bulbs need to be replaced but I'm worried that it may not help. The dots are colored red, majenta and yellow and they are always visible when the tv is turned on.
    Genius:
  • 1,153 Answers
Check out self test first, look at threads here or ctechnicians.com
Posted on Dec 31, 2007
I have a 55 inch rear projection mitsubishi tv. it recently has started showing what looks to be white spots when viewed at a distance on a dark screen. when you look at it closely it actually is red green...
It is called Convergence. You have three CRTs. Red, blue, Green. When they are not aligned, you will see the individual colors. See if you can do some alignment in the users menu. Look for Converge or Convergence in the menu. Either under video or setup.
Mar 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi HDTV 1080, model WS-55511. Color convergence is off but only on the outsides of the screen; in the center it is fine. Can this be fixed or do I need to replace the television?
Yes, it can be repaired, replace convergence out chips (two ICs) on main board.
If you are not comfortable with TV repair or have no experience, call local tech to fix it. Cost of repair would be $180 or so.
Nov 11, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Ws-55511 red color will not converge, got part
Remove the three screws from the main chassis than release up the two chassis lock on the right and left hand side than slide out you might have to move the DM module on the left side to get the chassis out.
Nov 09, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Powers on for three seconds then goes off
The first thing to do is to try to determine why the set is not turning on. It is equipped with a self diagnostic feature. On the front of the set push the MENU and DEVICE button at the same time and hold until the LED starts flashing a two sequence code. That will narrow things down for us.
Apr 28, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi Ws 55511
Good Day;
My opion is that the TV"s convergence Ic has failed > STK393-110 > 267P155010.
Good Luck, big IRISH.
Aug 10, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Ws-55511 power problem
Ok the 12 code means no error detected. Try this you will see three small wire plugs that run from the convergence yokes on the picture tubes. not the three big plugs, they will be real small plugs all identical. try unplugging them and then try powering up the set. But remember where each one was plugged so you can plug them back in correctly.
Aug 03, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
