Question about Samsung YP-K3 MP3 Player
YP-KR hi, I did install from original CD the program for Samsung YP-K3 it comes all on PC but not icon for portable device...PC vas asking for to uppgrade but vi /Sveden are not supported..what to do??? thanks
  • Anastasia_P Jan 02, 2008
    Hi I have the same problem but I dont know how you can add hardware??!!Help
  • Anonymous Jan 02, 2008
    no puedo conectar el portatil con el programa
I couldn't get the icon for the portable device either. I solved the problem by going to the Control Panel; used Add Hardware; and followed the prompts. I used the original Samsung K3 CD. And it worked! Good luck
Posted on Dec 31, 2007
Tip
How to make computer identify your device
I had a problem with my YP-K3 when i lost the installation cd as my computer no longer identified the device when i plugged it in, to solve this (on windows XP) go to
1: control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your mp3 player is now recognised by the computer
hope it works
on Aug 11, 2008 | Samsung YP-K3 MP3 Player
I cannot install my samsung YP-K3J MP3 Player onto my PC - HELP!!
Try to update the driver of the player.
Go to the START menu.
Click on RUN. type in devmgmt.msc and hit enter.
Make sure you have the player plugged in and the installer CD should be on your CD drive.
Now look for the category PORTABLE DEVICES or OTHER DEVICES.
the YP-K3 should be listed there with a yellow question mark.
Right click on it and select update driver. Follow the prompts to update.
The player should be recognized after that.
Hope this helps!
Jul 10, 2009 | Samsung YP-K3JAB MP3 Player
Portable device is not recognised yp-k3
try to go to control panel then ADD NEW HARDWARE
that do the trick..
Jun 18, 2009 | Samsung YP-K3 MP3 Player
Samsung yp-u3 mp3 cant create playlist
  1. Open My Computer.
  2. Right Click on the YP-T9J, then Left Click on Format
  3. Click OK at the warning message where it states that Formatting will erase all data on the device.
  4. Click on OK once the Format process completes, then close the My Computer window.
  5. Right Click on the icon of My Computer, then Left Click on Properties.
  6. Click on the Hardware Tab, then click on the Device Manager Button.
  7. Locate either Portable Devices or Windows Portable Devices and click the plus to the left of that to make it a minus.
  8. Right Click on the Samsung YP-T9 and Left Click on Update Driver, this will start the Hardware Update Wizard.
  9. If the first screen asks if you would like to connect to Windows Update and you are currently connected to the internet, select Yes, this time only, and then click on Next.
  10. On the next screen keep the default setting (Install the software Automatically (Recommended)) and click on Next.
  11. The wizard will search for an updated driver and once this is complete, click on Finish.
  12. If the Samsung Media Studio program does not open up at this time disconnect the reconnect the YP-T9J and this should then open the program.
NOTE: If this does not fix the issue, first try to uninstall then reinstall the Samsung Media Studio Program
Dec 03, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-K3 mp3 player requires driver but I have no cd!!
I've had this problem. Windows media player doesn't seem to find it, and I couldn't figure out which file I needed from the site. I have xp, but I'm assuming this might also work for vista. Go to Control Panel. Open System. Click the Hardware tab. Click the Device manager button. Find the yellow question mark labled Samsung YP-K3 and doubble click it. This should open a window that will let you (re)install the driver, which it will find for you after having you set up a few simple options. Hope this helps.
Mar 09, 2008 | Samsung YP-K3 MP3 Player
PC won't recognise portable device
i have the same problem with mine but it still charges i just cant put music onto it
Jan 31, 2008 | Samsung Yepp YP-T9 Digital Media Player
My YP-K3 won't turn on
Do you have mediaplayer 10 or 11 installed?
Media player 11 is seriously screwed up software and will cause your computer not to recognise the player
You will need to remove ALL traces of media player 11 from you computer.
Jan 16, 2008 | Samsung YP-K3 MP3 Player
Samsung YP-K3 MP3 Player Logo
78 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
