Question about Philips Magnavox MDV453 DVD Player
Magnavox mdv 458
I lost my owners manual. I just can´t get the logo of DVD on my tv screen.
I remember I have to open the DVD entry but I don´t recall wich button or buttons press on the remote control to get the logo back.
thanks for your help
  • 9 Answers
SOURCE: need remote control code
I found that on the back of the 2205 it said that the unit was made by Funai. I looked in the Innovage book and found that the codes for Funai DVD are 231 and 233. 233 worked on mine. Good luck.
Posted on Jan 06, 2008
  • 9 Answers
SOURCE: jumbo universal remote
SOURCE: no sound thru dvd player, but fine for tv and vcr
Just had the same problem and it is fixed for me. With NO DISC in the player go to the System Menu. Next Navigate to Preferences on the top of the screen.
You will set an option titled "Default". Select that and it seems to reset the player to default settings and fixes the sound.|
Posted on Jan 16, 2008
SOURCE: Remote Code for Magnavox DVD Player BDP170MW8 to LG HD-TV 42PC5D
Try Code 038
Posted on Feb 19, 2008
SOURCE: Magnavox MDV 630R/650R unlock code
sir please unlock code
Posted on Jan 02, 2009
SOURCE: I need the code Magnavox MWD200F DVD Player.
The code for MAGNAVOX MWD200F is 447 (247 partially works). It had been tested in two Philips universal remote controls (CL015 and CL035A).
Posted on Jan 19, 2009
0 characters
1 Points
On a magnavox mdv 460 dvd player what does it mean when the word root is on dvd srceen ?
'Root' is normally the name of the baseline user name for computer operating systems. It sounds like the system has somehow gotten into a programming mode. Here is a link to the manual:
Please refer to page 38 about upgrading the software. You may want to try the remote code to see if the system will return to normal operations.
Feb 27, 2015 | Magnavox MDV460 DVD Player
I have lost my magnavox dvd recorder manual. Where do I go to download another owners manual?
You can try contacting Magnavox (a Philips brand) or searching the internet for a copy or download. I have had good luck with downloading Magnavox manuals
Apr 03, 2013 | DVD & Blu-Ray Players
Rv screen to dvd how to hook up
It depends on the unit in the van and both units should have owner manuals that explain hook up. If lost or do not have Google the model numbers for "manual" to find an owner manual.
May 01, 2012 | Philips Magnavox MPD845
Does Magnavox mdv 2100/F7 dvd player have front panel display
This DVD player has no front panel display. Its front panel have ony two LED light indications, out of which, one is for power On indication and the other for p-scan [Progressive Scan] which will ight up when you select Progressive Scan function.
There are three push button switches, for Open/Close, Play & Stop.
It has only ON-Screen display system, which will be active only after connection the DVD player to tV. OK.
Feb 02, 2012 | Magnavox DVD & Blu-Ray Players
I lost the manual to the magnavox dvd/vcr dual player so i dont know how to set it up. so i can watch dvds and vcr tapes.
The easiest way to hook up the combo is to use the cable in and out to tv connectors located in the rear. for this connection you will hgave to set the TV to Channel 3 or 4. You can usually download an owners manual from, you will need a model number.
Mar 19, 2010 | Philips Magnavox DVD/VCR Dual Player
Cant record
CLICK HERE for a copy of the owners manual in PDF format.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 19, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Don know how to connect dvd to tv
lost manual need to hook up dvd to tv
Aug 03, 2008 | Philips Magnavox MPD845
I hae a Magnavox DVD player with remote but I have no instructions how to and what kind of cables to hook up with. Could I get an instruction manual from some one or maybe download it or send it to me....
The cables you ned will depend upon the inputs you have available on the TV you are using. Typically, AV cables are used (Red/White/Yel) to connect to the Video input on a set. Newer sets have both Component connections as well as HDMI. What are you intending to connect to?
Mar 17, 2008 | DVD & Blu-Ray Players
Philips Magnavox MDV453 DVD Player Logo
64 people viewed this question
Top Philips DVD & Blu-Ray Players Experts
Level 1 Expert
rugby prop
Are you a Philips DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
