I Connected my I Pod with the PC and went outside for three hours. After three hours when I came, I found that my I Pod is not booting. Please suggest how can I rectify?
I'm not sure if your saying it does not brew a cup of coffee at all or it is brewing but only cold water comes out. If it is just sitting there making a whinning noise and not delivering water it may just be dirty. To clean it you need to fill the resivior with a 50% white viniger and 50% water mixture. Run a brew cycle and let it sit for an hour. Then run several cycles through until it is out, refill the resivior with water only, run it completely through and continue with the water only until there is no more viniger smell or tatse. You will need to clean the brewer needle heads as well. Lift the handle to access the coffee pod compartment, remove the pod basket and use a paper clip to clean out the hole in the puncture needle. With the lever still raised, use the paper clip to clean out the three holes in the upper needle head. Replace the pod basket, close the handle and run a couple brew cycles through without a coffee pod.
Their directions sheet is incorrect. when the initial screen says save, don't click down load and be prepared to wait 1/2 an hour befor it starts. mine tried to down load over 6 times before it finally took. then I attempted to get on to the internet and msn was not one of their choices! also I was locked out of the three wi-fi stations that came on screen. I'm guessing this is a piece of hyped junk.
This worked for me: Went into SETTINGS > Wi-Fi > Selected my Network (which my iPod said I was already connected to) > Selected "Forget this Network" (which disconnects you from your network) > Re-selected my network and under password, I entered the 'Security Key' from my Verizon FIOS Tech Wizard info and the device accessed the app store successfully.
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
the machine might or might not have had the pod filter based on manufacturing date. If you did not have one it can be purchased on Breville USA web site for $10.
Download a free copy of itunes.after install plug ipod in and set-up.a new ipod does not have files required for loading.Your download is here https://swdlp.apple.com/cgi-bin/WebObjects/SoftwareDownloadApp.woa/2192/wo/axb8uETTTfApwgQBbo5pX0/2.5.If you require further assistance contact me here at FixYa.please do not forget to vote.RICHARDM69
Just charge the battery until the indicator says the battery is full. well since its been connected for more than enought, disconnect it, you can also try reseting the ipod incase it has frozen
To reset your iPod:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Managed to resolve my dark screen issue. It is a little weird and not sure which combination actually got it going but it works. I firstly connected the TV POD unit to the AV700 and used the remote and no joy. With the TV POD unit still connected, I fiddled with the battery latch switch a few times and VOILA! - the screen came back to life and all is now good. I hope it is as easy as that for all of you....
