Toshiba Satellite M45-S269 PC Notebook
Problem for Toshiba Satellite M45-S269 PC Notebook
Laptop does not like to boot, takes several tries
By jbass706 on Oct 24, 2009
Laptop does not like to boot, takes several tries to got bios screen. Sometimes BIOS screen shows up with missing or bad OSB LOGO. Is there a fix for this?
Comments:
Oct 24, 2009
- Thanks for the reply! I have had the display blink, but never shut down. I keep it on a "cool pad" and clean out the cooling system pretty regular. I have tried re-seating the ram, I'll have to give the CPU a shot. It has not gotten excessively hot on me...yet. I'll tear down and try re-seating the CPU tomorrow. Any chance the video GPU is socket mounted? When the trouble first started the external video would send info with the internal just backlit.
Oct 24, 2009
- Haven't tried a BIOS flash. Should I load the flash on a CD or can I use a USB thumb?
Best Solution
posted on Oct 24, 2009
Very Helpful)
KingDWS
Rank: Guru  Computer Hardware  Expert
Rating: 90%, 168 votes
If it is taking that long to get to the bios screen you may have cpu or ram problems. Toshibas tend to run hot and then the cooling system takes little to plug up and makes things worse. If it has ever turned off suddenly when running or been almost too hot to touch you may have damaged the cpu. Or if you get lucky it may have caused the ram or cpu to become loose in the socket. If you reseat them it can fix it. The ram is easy to get at but the cpu requires disassembling the laptop.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
eagle338
Rank: Wiz  Toshiba Expert
Rating: 84%, 1641 votes
You will probably have to reflash the BIOS, since this issue indicates that the BIOS is corrupted. You can get the BIOS from the Toshiba support site by clicking the link below. Note that this laptop model ships with many different motherboards so you will need to check yours and download the one that matches your board. Attempting to flash with incorrect BIOS may cause irreparable damge to your laptop.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=Satellite+M45&x=0&y=0
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite M45-S269 PC
Questions and Unsolved Problems for Toshiba Satellite M45-S269 PC
Do you recommend Toshiba Satellite M45-S269 PC Notebook?
Answer
Answer
Certified Data Laptop My screen won't come on. I can barely see it - but it is 'blackish'...HELP
Answer
On my Panasonic toughbook CF-W4 the page up, page down, and sideways arrows on the keyboard have... (More)
Answer
internal microphone for video chat isn't working. acer aspire 4810TZ. The only reason i can think of... (More)
Answer
i have a cracked screen and cannot read start up need to get documents from it
Answer
I have formated my Adilo hard drive because it would not boot, now I cannot perform a clean... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , NY
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
