Question about Breadman TR2200C Ultimate Bread Maker
I can't change cycles. The select button doesn't work.
My breadman didn't work for awhile. I unplugged it for a couple weeks and it started to work. The only problem is that now I can only use the basic white cycle. The select button doesn't work. Any idea's?
Thanks,
Jenni
  • Anonymous Dec 09, 2008
    Breadman Ultimate Bread Maker. Problem: Plug the breadman in, and green "warm' light comes on. The machine does not heat up or go through any cycles. Key pad will not work.
    Problem Solver:
  • 6 Answers
The microprocessor in the keypad probably needs to be reset. With the unit unplugged, remove the keypad housing (one screw in back, one on the left side, rock it up enough to get a small screwdriver inside, then push back the soft plastic fingers to release the housing -- force it a bit, you won't break it). You do not need to remove the bottom cover.
Remove the keypad cover (4 screws) and the PC board (one screw). You'll see a factory reset button near the middle of the left side. Press and hold that for a couple of seconds.
If you want to test the unit before re-assembly, hold the PC board so it doesn't short against anything (there's nothing more than 5v on the board, so you won't get shocked), and plug the unit in. The display should appear. Unplug the unit, re-assemble, and then bake some bread!
There is also the possibility that the backup battery on this PC board is bad. Check it with a voltmeter -- it should be about 5v.
Posted on Jan 26, 2008
  • stan ridgeway Jul 20, 2013
    Yup, worked for me. Big thumbs down to genius designed who placed a reset button in such an inaccessible place.
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Sep 20, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a Breadman TR875 breadmaker. It will not do anything when I hit start. I've tried to unplug it, but didn't help.
I believe for this perticular model to power-up, you must press the Select button first to select a mode, then press the Start button.
Here's more on the subject...
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source your accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reset the breadmaker by pressing down on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Note: It bears mentioning again at this point that some models require you press the Select button first to select a mode, then press the Start button.
Jun 20, 2011 | Breadman Kitchen Appliances - Others
I have a breadman trillium bread machine and when i put the ingredients in and select the setting and push start, it comes up with Eo2 on the machine and beeps. What am I doing wrong? I dont know if I have...
Good morning,
I have nearly the same unit. Per the manual: "the E:02 displays when you press Start button and it senses the Breadman is too cold. Unplug the machine and allow it to heat up to room temperature, then try again."
I've also heard that if you don't want to wait, you can use a hair dryer to heat surface!
Hope this helps. Have a good one
~PCF
Mar 05, 2011 | Breadman TR500 Bread Maker
Breadman Ultimate TR2200C: "--H Error"
I had the same problem recently, however my machine was in use. I unplugged the breadmaker, let it sit and cool. After 1/2 an hour, It was functioning properly. If this doesn't solve the problem, after plugging IN try holding STOP/RESET button for 3-4 seconds.
worth trying...
Oct 20, 2008 | Breadman TR2200C Ultimate Bread Maker
Whirlpool Du1148XTP Dishwasher
first off you posted this under the Washers not diswaher section if you have 7 blinking lights on the clean button you have a heater circuit problem
Mar 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Power won't turn on
Nov 11, 2007 | Breadman TR2200C Ultimate Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
112 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
