Question about Amana NDG7800AW Gas Dryer
It takes 3 hours to dry one load
My Amana dryer takes three hours to dry one load, I get more heat out of the medium setting on the dryer, what would cause this problem?
    President:
  • 1,314 Answers
Vent restiction look over the back of the drier and see if the vent is mashed folded etc then turn drier on go out side to where the hood is see how much air is comming out if very little find out whats blocking it
Posted on Dec 31, 2007
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Amana ALG443raw gas dryer
sounds like the thermostat is shot..do you fix this sort of thing yourself?
Mar 17, 2008 | Amana ALG443RAW Gas Dryer
Clothes not dry. Take about 3 hours to dry the medium load of regular clothes.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'
Jul 18, 2011 | LG Dryers
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Dryer does heat but takes 3 hours to dry a medium size load of clothes
Sounds like the moist air is not being properly vented. Your dryer has a fan that pulls in dry air and expells the moist air. This is vented thru your dryer hose and should be vented to the outside of your home. Sometimes the hose will get either a blockage or a partial blockage that will make it either not dry your clothes or take longer than it should. I have seen hoses that have a sag collect water much the way your trap will under a sink. You can either throughly clean the hose, and check for a blockage in the hose or the dryer itself, or you may, as a test, disconnect the hose temporarily and vent your dryer into an old pair of panty hose. When you turn the dryer on, the panty hose should inflate. Also make sure you keep your lint trap clean...EVERY LOAD.
Oct 02, 2009 | Amana DLE330RAW Electric Dryer
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Plugged venting causing low heat and poor lint output?
you need to check the dryer vent hole on the back of the dryer,make sure it's not blocked,also check the wall vent for the same thing,most of the time if there is a clogg it holds the moisture in the dryer and it take forever to dry,you can use a shop vac to **** out any clogged lint in dryer and wall ,then if you have a leaf blower put it on the wall side and blow it it all out.let me know how you do-mike
Oct 30, 2008 | Dryers
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
It takes hours to dry small load
dud thermal sensor, the temperature is shuttimg off too low
locate, replace the thermal sensor just 'downwind' of the flame
Mar 26, 2008 | Amana NDG7800AW Gas Dryer
Amana NDG7800AW Gas Dryer Logo
60 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
