Question about Denon AVR-3806 Receiver
Avr 3806 power shuts off when volume turned up
When watching TV my reciever will shut off when a loud scene comes on. I can turn it on right away and it will work fine on lower volume level.
seems like fuse is popping inside?
    Scholar:
  • 36 Answers
Hello david 420
It looks like your receiver's high-speed protection circuit is being activated. It is definitively not a fuse. When a fuse pops, you have to physically replace it. When the protection circuit is activated, the speaker output is cut off and the power supply indicator flashes. There are a few reasons why this happens:
1.- Your speaker wire connections are loose. Whether they are banana plugs or bare wire ends, make sure the speaker terminals on the back of your receiver are tight using clockwise turning.
2.- Verify that your speakers have an impedance between 6 and 16 ohms. Your receiver was designed to work with that impedance range. Any impedance lower than 6 ohms will activate the protection circuitry.
3.- The receiver is used at high volume levels over a long period, which results in an
extreme temperature rise. Improving the ventilation conditions around the unit might help alleviate the problem.
If after complying with these suggestions, problem is still present, you might need to have the unit checked by a professional for possible circuit failure.
Hope this helps. Let me know.
cancerags
Posted on Dec 31, 2007
Bd7200 shuts down from loud vibrating scenes
replace player sounds like a bad power supply or ic chip
Jan 21, 2013 | Samsung HT-BD7200 Theater System
Component video problem. Hi I got the Denon AVR-3806 receiver and has it hooked up with a component cable to my background projection TV. To the reciever I have a satellite box connected also with a...
Just fixed this myself - made my head hurt to figure out. 1. Switch to a setting (say DVD). 2. Watch the AVR screen as it switches. You'll see the audio and video settings. For example, Audio = DVD, Video = DVD (Mine showed Audio = DVD, Video = DBS even though is was set correctly using the SETUP for audio and video)3. Under the round control knob on the left, push the (tiny) Video Select button. 4. Turn control know to choose the correct video source
Your system should work right. Mine did.
Jan 03, 2011 | Denon AVR-3806 Receiver
I was watching a movie on my denon avr-3808ci and all of a sudden it made a loud sound and it shut off. The power button was flashing red and wne I tried to turn it on, the power button would turn green...
probably one of your speakers has blown.. disconnect them all. turn the reciever on.
if this works turn it off connect one speaker and turn it on.. keep going until it goes red...
when you find the speaker discennect all the other speakers keep this one connected and confirm that it is this speaker giving issues.
if the amp doesn't come on with all speakers disconnected, remove the visual outs and start it with nothing connected. isolate the issue if this works. otherwise it might be your amp.
Oct 24, 2010 | Denon AVR 3808Ci Receiver
When reciever is turned on it shut's right back off. It will not stay on. Also it would loose volume. Why is this and can it be repaired?
this is a main power issue and the only way to fix it is to replace the main board which is the heart of the reciever . costly exercise . sorry to hear that
Sep 27, 2009 | Harman Kardon AVR 510 Receiver
My Denon AVR 3806 keeps turning itself off, why?
Your receiver has short circuit somewhere. The protection circuit shut off the unit to prevent more damage. You can try to disconnect all speakers. If there is not improvement, you need to send your receiver to repair.
Jul 06, 2009 | Denon AVR-3806 Receiver
Multizone volume level is low
try switching the remote to operate zone 2 and turn the zone 2 volume level up higher
Jun 15, 2009 | Denon AVR-3806 Receiver
Avr Shuts down at high volume
It does that because there is a safety feature in all the newer devices. If your system is turned up to high you would blow your audio outputs or speakers. That's why it shuts off.
Jan 17, 2009 | Denon AVR-3801 Receiver
Volume Control
I had the same issue, there is a Late night mode on the remote that minimizes the volume of a loud scene so you don't have the constantly adjust the volume. Works great if you are trying to watch a movie while others are trying to sleep.
Dec 15, 2008 | Onkyo HTR500 Receiver
Reciever Powers Down
Hi...
Check ALL your speaker connections at both ends.
What kind of volume are you running it at and what kind of airflow do you have around it>?
Thanks
Aug 25, 2008 | Harman Kardon AVR 235 Receiver
Denon AVR-3806 Receiver Logo
435 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
