Question about Acer Aspire 3610 Notebook
Case Broken The upper case surrounding the monitor needs to be replace, but for the life of me I can't seem to find anybody who sells this. Any help would be apprciated.
  • streb Jan 06, 2008
    I need a REAR LCD LID for an Acer 3610, do you carry this part, and whats the cost?
    Thanks
I have not used this site, but it has the item you are searching for. I need one my self.
http://www.pchub.com/uph/model/0--4715-1/Aspire-9500-Series-parts.html
Russ
Posted on Jan 02, 2008
    Sergeant:
    Champion:
  • 310 Answers
Ebay is the bomb and if that dosent work go to your local repair shops and ask them if you can look in there bone pile!
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Dec 31, 2007
Where can I buy parts or a replacement?
There are many websites that sell replacement screens. Some even supply the special tools to open the case too. Just google cell phone replacement screens.
Jan 27, 2016 | Blu Life Play Mobile Phone
Upper thread is not catching bobbin thread
Carmen, seem that you have carried out the necessary rectification, but could it be your rotary hook tip blunt/broken, if not most probably it needs needle/hook timing adjustment. And this will require your sewing machine technician to do it.
Jul 24, 2013 | Sewing Machines
My lower case e shows vertical lines, the upper case is fine as are all other keys
The lower case "e" spoke on the print wheel is either bent or broken. If it's bent you may be able to straighten it, if broken it needs replaced.
DickyO
Dec 21, 2011 | Lexmark Wheelwriter 6 Series II Typewriter
I need to buy a soyo pentium3 7vba133u motherboard. anybody have one to sell?
It is highly unlikely a Pentium 3 motherboard is available let alone a SOYO P3 motherboard.
Motherboards and desktop cases have standard mounting holes, I would suggest you buy a late model motherboard that suit your requirements and mount it in your desktop case. You need to be sure the ATX power supply is adequate power output.
Better still just buy a new computer, you don't need a buy a new monitor.
You can reuse the old hard disk and put it into an USB hard drive adapter case and use it as an external hard drive.
Dec 17, 2009 | Computers & Internet
Dell 1704FPT just went dead, will not turn on not even yellow light on power button - just seems to have died. Is there a way to reset? or is it time for a new one?
First you need to troubleshoot a little. You should first try another power cable for the monitor, if that doesn't help, you might be able to open up the monitor case and check wether the button is broken. If the button is broken, you're going to have to improvise a new one, since new buttons aren't really being sold. If that isn't the case, or if you can't open up the monitor, take it to computer shop, these things are easier to fix if you can look at it. I hope this helps, Yannick.
Jun 06, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
How can i open the body or case to repair of hp
Please check first if your LCD monitor is still under Warranty period, if yes, then I recommend to bring the unit to authorized service center to properly diagnose & fix the problem, because if you open it yourself & probably broken its seal then the Warranty will be Void & other problem/s that may arise / found will no longer be covered by their free service / part replacement.
If no longer covered by a Warranty, then you can open it by yourself, by turning (counterclockwise) its lock screws to open its back cover & check the circuit board parts / connections if loose/broken/defective. regards
May 17, 2009 | HP f2105 21" LCD Monitor
My BenQ FP757-12 monitor stopped working
I commend your courage in taking your monitor apart. I hope it was out of warranty when you did it; because it is out of warranty now.
I have no idea where to find the info you are looking for. Monitors are cheap now, though.
Dec 28, 2008 | BenQ FP757-12 17" Flat Panel LCD Monitor
The Ds lite powers up for a brief moment then crashes
well try to find DS parts in EBAY...
and don´t try to power the DS with a broken display ´cause it can short-circuit another part of your DS...and make things go Bad...
good Luck!
Dec 05, 2008 | Nintendo DS Lite Console
ACER n30 PDA - RENEW THE BATTERY?
There is a lot of very confusing information about this battery pack and PDA - many companies are selling the battery without instructions and many reviewers/users claim that there is no way to replace the battery. Acer makes no mention of this either way and didn't seem too keen to answer the question. The screws that you mention appear to be the ones as at least one company is selling the battery with a screwdriver included that appears to be the one for the four thin screws. Just make sure there are no other screws hiding under a sticker or similar - running a stylus over any stickers should reveal any potential screws that may have to be removed (almost certainly opening the case will void the warranty if still an issue) Another company is also selling an "unmarking case opening tool" which is essentially a small plastic spatula - therefore I believe that when the screws are out you should be able to push something gently into the gap between the shells, popping it open - from photos it would appear that the small groove between the shells in the corners are the places to start. BE gentle and careful with this as the possibility of damage is there, but once one part of the shells start to separate you should be able to see clearer what is holding them together. If you want a bit more info then try e-mailing these guys; http://www.pdasmart.com/pda-battery-center/battery_ACER_ACER-N30_battery_center.htm They should be able to help as they do sell the battery and are well respected. Hope this helps and good luck :) - if you are in any doubt about doing it yourself then i recommend finding a repair shop near you, although I cannot believe it is too complicated to open. if there is any confusion about actually swapping the battery once the case is open, please post back with a photo of the inside and I hope we can help, but i think it should be easy enough once you are in - make sure you ground yourself properly and touch as little as necessary when inside.
Jun 08, 2007 | Acer n30 Pocket PC
Acer Aspire 3610 Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
