Question about Samsung SPH-M500 Cellular Phone
Display Contacts name is not displayed for incoming calls. Only phone # is displayed.
    Problem Solver:
  • 9 Answers
You need to associate those phone numbers in your addy list on the phone for the name to appear...
That person also needs to update their vision profile
Posted on Jan 15, 2008
I have bought Nokia E63 mobile. I have saved all the contacts from my sim card to my mobile, but while receiving the incoming calls the names are not displayed in the mobile and only the mobile numbers are...
The problem here would be duplicate contacts. When a call comes it searches the number in the Phone and SIM and displays the name pointing to that. Here in your case I suppose the same contact with the same number would be entered twice ( SIM + Phone) and phone gets confused which name to display and it shows just the number instead of name.
To solve this what you can try is to disable the SIM contacts from displaying. To do that go to Menu>Contacts>Options>Settings>Contacts> Contacts to display - Select Phone Memory only.
Hope this helps. Good Luck. ~SmokinJoe~
Apr 28, 2011 | Nokia E63 Cell Phone
The name of the caller is not displaied
Why does my Nokia device only show phone number of caller or SMS sender, although they are listed in my contacts? The calling phone number may not match with a contact name and the name is not shown in the following situations when an incoming call or SMS arrives:
  • The contact is defined twice in the Contacts application (e.g. if both Phone memory and SIM memory contacts have been selected to be displayed in Contacts settings and the same contact is found in both of them).
  • The same phone number is defined for two or more contacts.
  • The phone number in Contacts application is in different format than the number received in the incoming call. The phone number may have been stored in local format while the incoming call number is in international format (including country prefix), or vice versa. The number may not be properly matched with a contact name in this situation, depending on the device variant and the length of the calling number. In order to verify the correct format of the contact phone number (local or international), check the number which is shown when the call is received and edit the contact details accordingly.
If the problem persists, make sure your Nokia device is running the latest software. For downloads and assistance, go to your local Nokia website.
Jan 19, 2011 | Nokia C7 (8 GB) Smartphone
Dear Sir, I am using Samsung SJ700 mobile phone.And sometimes I get incoming call with no number displayed on the screen. It just shows incoming call. Can you pls help me in sorting out this...
This happens when two or more similar (saving one number with different names) contacts is saved on your phonebook, i.e. if you've saved my number on the sim card with a name and at the same time you have my number (same number) on your phone's memory, the caller id will not be displayed, you'll only see the "Incoming Call" or "Call". So I would suggest you to please check the phonebook and delete (keep only one per number) if there are multiple similar contacts saved on your phonebook.
You can also reset the phone to Factory default, in case there's no problem with your phonebook/contacts.
Good luck.
Thanks for using FixYa.
Aug 14, 2010 | Samsung Cell Phones
Incoming phone number displays but not the name in
Some nokia set has this kind of problem as we dont store the names with '+91' . This problem can be solved if the no is saved with '+91'.
thanks,
saumya.
Aug 04, 2009 | Nokia E63 Cell Phone
How get do I get my incoming phone numbers to be displayed
Most phones will only do what you require if the contacts are stored on the phones memory instead of the SIM memory. This will also prevent you from assigning photos to contacts and one touch speed dials (i.e. press and hold a number to dial a stored number) Try copying all your contacts to the phones memory. If you see duplicate names, go into phone book settings and adjust setting for phone just to look at phones memory and this will stop duplicates being shown. hope that helps?
Apr 26, 2009 | Nokia 6600 slide Cellular Phone
Could not get the calls in my phone
Dear Madhavi
1) Problem in incoming call will be issue of network error, check with the operator service provider or try typing *#3370# for increase network receptionn but it will drain ur mobile charging
2) contact not displaying will be occur due to low memory problem but continue with restarting & keep backup of ur cause it will be helpful incase if they have not retrived by restart
3) You have duplicate entry saved in phone & also in sim card in that case phone dont shows name & shows only no. So please delete & try to keep contact only in sim or phone memory
Hopes above solution will be helpfull
Please revert ur comment or rate above solution
Regards
Pin2
Mar 02, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Savin masages
you have to install pc suite and then start saving phone book contacts and messages. For caller name, you have to do settings in the contacts, as to which contacts you want to display on your phone
Dec 05, 2008 | Sony Ericsson K750i Cellular Phone
Help with incoming calls
It could be a setting in the phone that he may have changed. Look around in the settings to make sure yours is the same as his.
May 02, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Samsung SPH-M500 Cellular Phone Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
