Question about RCA TH1101 MP3 Player
La musica se corre, quiero decir que cuando lo pongo a reproducir la musica salta de 00:01,00:07,00:15. y asi sucesivamente, tambien cuando lo pongo en el windows no me deja tener acceso al mp.
  • 8,596 Answers
Make sure the songs are in the correct format. Make sure the songs are not AAC, WAV, streaming, or some other non-supported format
Mp3 players are more complicated than ever. This player may only accept DRM-encrypted WMA files. I would first check the songs that you have downloaded to make sure they did not have "temporary" licenses with a fixed end date. You can do this by right clicking on an individual song, clicking on properties, and selecting the "license," "digital rights mgmt" or "media usage rights" tab - the wording varies by configuration. It will give you info on the license. If the song says that it has no license, it will not work with this player. One remedy is to use mp3 converter software to convert all of those wma files to Mp3's - I don't know of any free ones, but you can certainly look for free Mp3 Converters. Another remedy on unlicensed songs is to hit the "acquire license" link in the license tab, if one exists.
-Tha Mp3 Doctor
Posted on May 24, 2008
Mr garcia mi carro se apaga cuando lo quiero prender ,parece que la alarma se activa y no me deja prender el carro
viejo tengo un camaro chevrolet modelo 80 pero excelente motor ,,venia funcionando bien , y ahora lo enciendo y se apaga , creo q es el distribuidor, no se creo ,,q sera ,,la bateria esta cargada , el alternado le pongo un bombillo ala salida y prende ,,q sea,,por q se apaga cdo lo arranco
Jan 06, 2013 | 1992 Lexus Es 300
Where is the fuel pump relay located at?
behind left kick panel, asi dice en el manual, yo te podria decir que va detras del poste de la puerta delantero izq., el poste es donde van fijas las bisagras de la puerta, del lado del chofer, a la par del modulo ABS, por lo que se ve quitas una ventanilla de plastico (tapa) y detras de ella esta el modulo ABS y 2 relays, para que lo identifiques checa el color de los 4 cables q le llegan; Cable No. 1 *****/rojo, cable No. 2 *****/rosa, Cable No. 3 *****/amarillo, Cable No. 5 *****/blanco, en la cavidad 4 no lleva nada, suerte amiguito. pdta. este auto tambien lleva un modulo de control de bomba de gasolina tambien llamado FPCM que va ubicado en la parte trasera izquierda, (Left side of trunk) y tambien le llegan 4 cables.
Nov 30, 2011 | 2000 Nissan Maxima
Por que el audio de mi computadora se escucha un poco mas rapido de lo normal, yla voz se ecucha como la de las ardillitas??
Si eso le esta ocurriendo cuando usa determinado programa verifique la configuracion del mismo. Otra sircuntancia seria que tuvieras algun tipo de virus o troyano que te este afectando el sonido. El problema que esta teniendo no es habitual y es la primera vez que leo algo asi. Te recomiendo que con tu maquina desconectada de internet le hagas un escaneo profundo con un buen antiviru y tambien verifique las aplicaciones (si fuera el caso) que estes usando cuando te sucede la situacion a la que haces mencion.
Suerte y gracias por usar FixYa.com
Jan 11, 2011 | Computers & Internet
No puedo integrar musica a ipod si pongo musica se borrn
Tienes que usar el ordenador que se uso antes de ahora en este caso!
En otras palabras los Ipod solo funcionan si se registran con el orrdenador de inicio cuando se isntala la musica pero usted puede registrar mas de uno solo si la misma musica se encuentra en el otro ordenador que tiene la misma musica instalada en su itunes.
Espero que mi informacion le ayude a entender, gracias
Nov 28, 2010 | Apple iPod nano
LA PANTALLA SE PONE COMPLETAMENTE NEGRA CUANDO ENCIENDO EL AIRE ACONDICIONADO Y SOLO SE ESCUCHA
Dependendiendo donde vivas, y si esto solo ocurre cuando enciendes el aire, es simple que la misma linea que alimenta el aparato de aire acondicioneado, es la misma que esta supliendo energia al TV. El area donde vives debe tener problemas con caidas severas de voltage. Los equipos cuyo consumo de potencia es menor que la inmensa demanda de potencia que requiere un acondicionador de aire, tienden a llevar la peor parte del sunministro electrico. Te recomiendo que busques otro toma corriente para suplir el TV, y para estar seguro de que lo estas colocando en una linea que no esta con el aire, sin encende el aparato de aire acondicionado enciende el TV y ve te a la caseta de breakers, ve bajando (off) uno por uno hasta que veas que el TV se apaga, ponle una matrca a ese breaker ya que es el mismo que suple el aire. Luego conecta el TV a otro tomacorriente y repite el proceso (asegurate tambien de que la nevera esta apagada) si ves que en un breaker diferente al que marcaste hace apagar la tele, entonces dejala en ese toma corriente y con todos los breakers arriba (on) enciende el aire acondicionado) si no sufre la tele, ya resolviste el inconveniente, pero si se vuelve a poner negra, busca un multimetro o tester y asi con el aire funcionando, pon el multimetro en la funcion de voltage AC (voltage alterno) Y mete cada uno de los terminales o puntas del multimetro en un tomacorriente (no hay peligro alguno, el multimetro solo mide) deben haber 120 voltios aproximados con un descenso s ascenso de un 10%, es decir entre 108 a 132 voltios. si baja mucho menos el valor de lo que especifique, entonces tienes un serio problema con la energia que te suministran a tu casa. Si eso ocurre, me escribes y te doy una pequeña solucion a eso...
Dec 29, 2009 | Televison & Video
Cuan do entro en el programa de you yube y pongo el nombre de un artista no aparese el video ni la musica
Trata de revisar si el nomber del artista o la cancion estan escritas de la manera que piensas, y despues buscalo en Youtube.
Si todavia no lo encuentras, quiere decir que el video todavia no esta disponible o estaba, pero lo boraron the youtube.
Jul 16, 2009 | YouTube Videos
Tengo una DN hd2500 y se bloquea
bueno, la cosa esta asi, basado en lo que a mi me ha sucedido, yo uso la dn2500 y  le doy mucho uso, a mi me *** ese mensaje varias veces, db save ng! , cant acces, eso es cuando tu disco duro esta fallando o ya murio o no lo puede encontrar, pero cada ves que me paso eso fue llegando al lugar de trabajo, me volvi loco , desconecte el teclado y la volvi a prender y se solucionaba hasta que un dia no arranco mas, entonces saque el disco duro interno y lo quise poner en una caja para copiar la musica a otro disco duro, hecho esto volvi a poner el hd en su lugar y funciono, yo creo que es un tema de los conectores, pero tambien podes ir a utilidades y probar hacer una base de datos nueva. lo importante es sacar la musica que tenes ahi, despues te compras otro disco duro($40) y lo cambias por el que esta ahi adentro o lo usas por usb externo, recuerda que el usb externo tiene que estar formateado en fat 32. aca esta mi email por si necesitas algo matosfilms@gmail.com
May 04, 2009 | Denon DN-HD2500 MP3 Player
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
Hola que tal!
Hola,
Tu pantalla tiene 2 sintonizadores, por que no intercambias tu antena y pruebas si de misma forma la falla se sigue comportando, o por lo menos cambia... ejem: que ahora falle el recuadro mientras que el principal ya no. De ser asi, acorralamos en mucho la falla en el sintonizador ya que un sintonizador es primario y el otro es secundario para funcion recuadro.
Prueba y me dices aprovecha, en este momento tengo una identica a la tuya en servicio!!!!
Si resuelves el problema, no olvides calificar mi asistencia
saludos y suerte.
Adonisito
Mexico
Mar 13, 2008 | Mitsubishi VS-50609 50" Rear Projection...
RCA TH1101 MP3 Player Logo
53 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
