Question about Acer TravelMate 290 Notebook
Computer shuts down and tries to reboot in an endless cycle
When I turn the computer on, starts and works fine for some minutes, After that, it shuts down and tries to reboot, in an endless cycle, not loading windows xp. If I shut it down manually, it will restart after some hours, but shall repeat the same routine.
  • 81 Answers
This sounds like a heat related issue.
Are you sure that the CPU fan is running and that the vent ducts are all clear?
You maye be able to get it cleaned out with a can of compressed air.
Is the computer new? If so, then it is probably not dust, but if it is more than a couple of years old, then that is probably the problem.
Posted on Dec 31, 2007
My iPhone 3GS won't boot (Endless Reboot). Can't enter into DFU to restore.
You almost had it. First have it pluged in like u did. Then while its trying to start hold the home and power button untill it turns off like u did at the end. Last release the power button but hold the home button down. Do not let go of the home button untill it works. If it wont it will reboot like it had but it will work.
Apr 11, 2013 | Cell Phones
Shuts off and reboots then shut off in the middle of reboot.
these posts are endless here, truely
had to google it ah a DESKTOP
old Pentium 4 processor
circa 2003 , tiny HDD, and memory. old, Goodwill has 1000s parked.
well it can be many things,
did you remove all the cards first, (yes all)
does that hold up power? now?
it will beep, like that, if video car is pulled
and then pull memory, and it will give the ram missing beep codes
all this is covered in the great HP service books.,
beep codes and all
the power switch can be bad or the line cord. to wall. bad.
the power switch unplugs and you can short its 2 pins
to turn on PC< hold up now>?
hold up, means stay running,
you can strip it down, to just mobo and PSU
sure can,.
the CPU can overheat, sure can. and can be checked.
cpu fan works so is not that. im sure. and new thermal grease.
data sheet shows. (pull it,?)
nVidia GeForce4
GeForce4 MX
MX
440 440 AGP
AGP 8x
8x graphics
graphics card
card
Mar 12, 2017 | HP Pavilion A250n (DF253A#ABA) PC Desktop
I have an Asus P6T motherboard. If you turn on the computer after leaving it off all night, it will turn itself off immediately after reaching the Windows 7 logon screen. Then it turns itself back on,...
test all leads that attach to your hard drive electrical,IDE,SATA even electric extensions also from your motherboard to your hard drive also test all drive leads cd,dvd,3.1/2 floppy
hope this helps
Aug 13, 2010 | ASUS P6T Deluxe Motherboard
Troubleshoot motherboard
It's hard to do much testing, but I'd look for capacitors that are bulged or leaking. badcaps.net has way more information than you'd ever want to know about this problem
Pull everything out and reseat it, see if it works.
After that, I'd pull everything out but the motherboard, one stick of known good memory, and the video card. Also disconnect everything from the back but the keyboard and monitor. Clear CMOS using the correct jumper.
Boot up to the cannot boot prompt and let it sit for a while (15 minutes or so). Do a ctrl-alt-del and see if it reboots correctly.
Next, add in just the cdrom and boot off of it until it fails (win xp setup) Then Ctrl-alt-del and make sure it works a second time.
Now, add your hard drive and try to install. If it works, shut down, add one card at a tie back in, and test each time.
Then start adding in your usb devices, then network cabling, etc etc.
If you can, try a known good power supply.
Either you'll find the part that is causing the problem, or you'll know it's most likely your motherboard.
Sep 27, 2009 | EliteGroup 848P-A Motherboard
I cannot logon to my PC
Start your PC in safe mode, to do this repeatedly tap the F8 key as soon as you turn the power on. This will then bring up an "options" screen listing boot in safe mode, safe mode with network support etc. Just use safe mode. If it goes directly to windows instead - shut it off and try again til u get the safe mode screen. The arrow keys control the selection to choose.When it starts in safe mode a black screen will usually appear with a bunch of writing, this is normal, after that it may "hang" for as long as 5 minutes, before coming up with a login screen. Sometimes hitting enter or escape will bring up the login screen faster. When you have a login screen, login and disable the updates using the software control options for the software that is trying to update. You might also go to control panel, administrator options, then services and disable automatic updates temporarily. When your pc starts in safe mode - it starts with minimal drivers and does not run updates- this allows you to change settings. You can then reboot normally and it should start properly without updating before starting.
Aug 29, 2009 | Acer Aspire AM1610-U1201A PC Desktop
Dlink router, Dell laptop - no connectivity - won't renew IP
resetting netsh was a good start. I would suggest starting with pulling the power on the router for about 5 to 10 minutes and then plugging it back in. give it a couple of minutes to reconnect to the modem and then try connecting to it again wirelessly. I had an issue with my dlink gigabit that stumped me and a cold reboot was the only thing that worked
Jul 15, 2009 | D-Link AirPlus DI-524 Wireless Router
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
Linksys WMP300N Endless Bootup Loop
Disable or uninstall the Linksys software that manages and monitors the connection.
Use instead the Microsoft Windows Wireless configuration utility.
That's what I did and didn't get problem after.
Dec 30, 2007 | Linksys WMP300N Pre-802.11n Wireless...
Acer TravelMate 290 Notebook Logo
167 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
