Dishwashers Logo
Posted on Oct 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Help with and f4 fault code on a fisher and paykel disher
Kevin
Level 2:
  • Expert 79 Answers
  • Posted on Oct 24, 2009
Kevin
Expert
Level 2:
Answers
79
Questions
Helped
74912
Points
285
Without the model number I have to guess.
Fault code 'f4' means "faulty temperature sensor or element".
Here is a link to User manuals:
http://fisherpaykelparts.net/index.php?blockitemid=29
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Fisher & Paykel GWL11 top loader. Fault code 136. How to fix the problem, the washer won't spin or drain.
Question edited for clarity, turn question around, add CAPS.
It is a motor stall. You need a technician.
Washing Machine - Top Loader Fault Code Numbers
Fisher & Paykel https://support.fisherpaykel.com > article > Washing-M... Sep 30, 2023 - 136, Motor Error - You will need a Service Technician to assist with this - Click Here to ... © Fisher & Paykel Appliances Ltd 2023. Loading.
Questions & Answers for: fisher paykel fault code 136
Fixya https://www.fixya.com > ... > fisher paykel fault code 136 Now Error code 136 means you have a motor stall ... Question about GWL11 Top Load Washer. 1 Answer · What is fault code 136 on fisher & paykel ...
I have a fisher paykel GWL11 that will fill and drain but
JustAnswer https://www.justanswer.com > Appliance Repair May 25, 2017 - If you had a 130 and a 136, the sensor is not likely the issue. Will the tub turn manually? How about lift up and down? Ask Your Own Appliance ...
1 answer · Top answer: Oh, that plastic nut will come off. See the link below. CLICK HERE
https://www.google.com/search?q=Fisher+%26+Paykel+GWL11+top+loader.+Fault+code+136
What error code is on Fisher and Paykel dishdrawer DD60DDFX9 flashing leds
About the F4 error code on the Fisher and Paykel DD60DDFX9 dishwasher:
The F4 error code on your DD60DDFX9 dishwasher indicates a fault with the heating element or the temperature sensor. When the dishwasher encounters a heating fault, it is unable to heat the water to the correct temperature required for the wash and rinse cycles. This can result in poor cleaning performance and may also affect the dishwasher's ability to sanitize the dishes.
To troubleshoot the F4 error code, you can try the following:
  1. Check the heating element: Use a multimeter to test the heating element for continuity. If the heating element is faulty, it will need to be replaced.
  2. Check the temperature sensor: Test the temperature sensor using a multimeter. The sensor should show a resistance value of between 10,000 and 12,000 ohms at room temperature. If the resistance value is outside of this range, the sensor may need to be replaced.
  3. Check the wiring and connections: Inspect the wiring and connections between the heating element and the control board. Make sure all connections are secure and free of damage or corrosion.
  4. Check the control board: If the heating element and temperature sensor are both working properly, the issue may be with the control board. A certified repair technician will need to diagnose and replace the control board if necessary.
Fisher & Paykel dishwasher. Why is it displaying fault F4?
According to the owners manual that fault code is for a faulty temperature sensor or element. It also says to contact an Authorized Service Center. Hope this helps!
I have a Fisher and Paykel integrated dishwasher and there is no lights working on the switch on the top drawer and when the power is turned on and off it says it has an f4 fault on the internal panel. The...
F4 implies a problem with water heater not working or temperature sensor giving wrong value. Check if the drawer is cold or too hot at the time of the error.
Fisher and Paykel Dishdrawer-DS605SS F4 fault code
No temperature increase has been recorded when the element is on.
The element is not connected.
The element has gone open circuit.
Temperature sensor or electronics ADC has failed.
F4 fault on fisher paykal dish drawer
F4 fault would inidicate the temperature sensor that senses the water temperature is faulty or the heating element is not working.
Looks like you will need a technician to visit and have a look.
Top Fisher Dishwashers Experts
vince
NOEL
NOEL
john h
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
