Question about Hitachi CMP4201U 42 in. HD-Ready Plasma Television
Black line down the center of screen
I have a black line down the center of the screen of my Hitachi Plasma TV. The line comes and goes.....
I had the same problem to and I fixed it.
At the bottom of the plasma there are six or seven ribbon cabbles that come out of the panel and connect to like driver boards. Each ribbon drives that section of the panel. Mine had it down the centre so I unplugged that ribbon cable and on the underside of a metal plate attached to it there are four big resistors and four small ones. The big ones labelled 100 required resoldering. Once they were resoldered it worked just fine.
Posted on Sep 24, 2008
    Genius:
  • 1,153 Answers
Usually this means pixel, but I would question if the line is mostly near right side or left side of screen? If more to one side this could be a bad board inside. for more info ctechnicians.com
Posted on Dec 31, 2007
Have a black line coming straight down centre of tv
Bad tab bond. try twisting the tv by holding the top corners and lightly twist to see if it comes and goes
Aug 08, 2012 | Hitachi 42HDS69 42 in. Plasma Television
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black line on plasma tv
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 19, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black Line Down Center of Screen
Dry solder joints on the pins of the vertical integrated circuit may have caused this problem Tap each I/C lightly with a plastic screwdriver handle to find the intermittent one. It is the one with a heat sink attached.
Aug 10, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42EDT41 plasma model-1" black stripe on right side
This is an old post but maybe it will help others. You will have to take the back off of the TV. On the bottom you will see ribbon cables coming from the screen and connecting to 3 PC boards. Take the screws out that holds the cable down. Underneath you will see 4 resistors marked 100. All you have to do is re-solder the resistors and your vertical line will be gone. You need to be good at soldering or you could damage the ribbon. The only ones that you have to re-solder is the ones in line with the lines on the screen.
Jun 06, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black lines on plasma
The matrix controler or the matrix drive area is failing. The fix is to change the proper circuit boards, and then do the factory setup to match the board is necessary. In the worse case, it may be the display screen itself that has a failure occuring.
You will have to bring the set for factory service to have the work done. If the set is out of warranty, it may be expensive to service.
Jerry G.
Apr 12, 2008 | Hyundai ImageQuest HP4240 42 in. Plasma...
did you fix the black line? please let me know as my TV (same model) has the same problem.
Jul 14, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black line in center of screen
These black lines on the plasma screens are very fixable.  There is a dry solder joint on a circuit board at the bottom of the plasma that needs resoldered.  There are 6 or 7 "ribbons" along the bottom of the screen that correspond to vertical sections of the display, so you just follow the black vertical line down to figure out which one is faulty.  I just performed this fix successfully on my first attempt on a Gateway plasma, but it will work on most plasma's, specifically Hitachi, gateway, LG, Hyundai, & Akai. I think they may all have LG boards, my gateway did.
I can't really describe very well what to do, but I assure you it is fixable.  If anyone is near nashville, I might be able to help you out.  My email is tomp2000@juno.com.
thanks,
ST
Jan 18, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi CMP4201U 42 in. HD-Ready Plasma Television Logo
409 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
