Question about Dell Latitude D600 Notebook
Laptop not starting up in Windows
When I turn my computer on, a screen comes up that says Windows did not start successfully. Towards the bottom it gives me options of starting in Safe Mode, Safe Mode with Networking, Safe Mode with Command Prompt, Last Known Good Configuration and Start Windows Normally. None of these options work.
  • Anonymous Mar 19, 2014
    my laptop is not starting normaly but it can start by safe mood and debugging mode why is that? it always warms up and became hot and blows alot of wind
    Sergeant:
    Champion:
  • 362 Answers
You are having a bios problem you need to look at your owners manual and see what key you have to hit during startup to enter bios, some you push delete, some F!, some F8, but push the appropiate key then use the motherboard manual to check the settings of your bios, all these should have come with your machine new. if bios is configured correctly and it still dont boot while in bios disable your CPU internal cache, make sure your HDD S.M.A.R.T. is enabled, and make sure that your hard drive is listed as detected in intergrated periphals , if its name and size isnt listed select detect and hit enter if it dont detect your hard drive could be bad or another problem if it does then you sre ready to use the system to trouble shoot itself. just follow the directions on the screen.
Posted on Dec 31, 2007
  • 81 Answers
You may be able to save it with a "repair install" of your operating system.
Don't know if the Dell recovery discs allow this or not.
Before you do that though, find someone who can remove your drive a save all the DATA off of it that you might want to save.
If you have a little bit of mechanical abilty, you can by a USB to IDE adapter to plug the removed drive into a USB port on another computer and save your DATA before starting any recovery operations. these adapters can be had for under $20.
If you don't have anthing on the computer you want to save, then just insert your recovery disc and go for it.
My MX6214 Laptop will not start windows XP, a series of white vertical lines comes on in the bottom of the screen and after they all turn solid windows screen comes on but never starts, I tried a new hadr...
THERE SHOULD BE PROBLEM WITH THE RAM. PLS CHANGE THE RAM AND TRY. OR IF YOU HAVE 2 RAMS INSTALLED TRY REMOVING 1 AND TRY. THE RAMS ARE GENERALLY PRESENT IN THE CENTRE IN THE BOTTOM SIDE OF THE LAPTOP. PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Gateway MX6214 Notebook
My laptop wont come on a screen keeps coming up asking to repair or start windows normally i have tried both without success
When was the last time you were able to use your computer?
Did you installed any software recently in your computer?
Try pressing F8 on startup and use the Last Known Good Configuration. May be that will help.
Feb 28, 2011 | Toshiba Satellite Laptop L655S5150
Turn my acer aspire 3680 2022 on and get a screen that said we apologize for the inconvenience but windows did not start successfully. a recent hardware or solfware change might have caused this.then it...
It appears that the issue might be with some hardware malfunctions. It may happen due to hardware failure, BIOS mismatch or due to
static charge. Let us try the basic troubleshooting. Turn Off the
Computer, remove all the devices attached to the computer, the power
cable and battrey, now holdon the power button for 15 secs (make sure
adpater and battery are uplugged) it will drain out all the static
charge. Now, restart the computer and keep on tapping F2, you will enter
to BIOS setup utility, press F9 (click "Yes", if you are prompted) and
then press F10 (Click "Yes", if you are prompted), it will restart the
computer. If still it is not booting to normal mode, then we have to
perform a full system recovery & it is a distructive process as you will
loose all the datas on the computer. To do so, Turn Off the computer,
now as soon as you hit the power button, keep on holding "Alt" key &
keep on tapping "F10" key, i.e Alt+f10, it will open the recovery
console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer
May 21, 2010 | Acer Aspire 3680 Laptop
Turn on laptop, windows did not start successfully comes up automatic, safe mode etc have tried, none works goes into totoshiba screen and stright back to windows did not start up.i know nothing about...
select the last good known options and press enter ...if it will work ... no issue ... if it will not work you have to install the os againe ..........
Nov 04, 2009 | Toshiba Satellite Pro L300 Notebook
Won't boot up, windows won't start successfully
In fact, your computer is restarting by itself after a problem. On Windows 98/2000 the blue screen was sitting there until you rebooted the computer. Windows Xp reboot the computer sometimes even without showing any error message. The thing is, if it reboots even if you select Safe mode, something may be wrong in your hardware (i.e. your memory or hard drive). I would bet on a memory failure but it's hard to be sure unless you boot your computer with a memtest CD, you can find it for free the internet and select your CD as booting device when the computer starts. If you cant do that yourself, you can bring it to a local computer store or anyone with good computer repairing skills. If you need more help with this, let me know
Jun 08, 2009 | Toshiba Satellite A105-S171 Notebook
Start up issues
go onto the bios after pressing f2 and look through the options and tabs and tick or change whichever option is about the setup or start up
May 01, 2009 | Acer Aspire 5315 Notebook
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
Black screen comes up "windows did not start successfully...." choose from safe mode, safe mode with networking etc Last known Configuration or Start Windows Normally. Computer then tries to...
You should opt Safe Mode:
  • On the black screen just navigate throug up and down arrow keys.
  • Goto Safe Mode and press enter.
  • It will boot your system in safe mode.
If the boot is success full:
  • try to remember any software or hardware you recently installed/change. Then remove/uninstall that software/hardware. Also remove some device driver like Video/Audio driver and make re-start. and try to normal boot. If success then install your audio/video.
If no success then I think its time to re-install your windows.
Please post your feed-back.
Gud Luck
Iqbal
Apr 20, 2008 | Computers & Internet
Dell Latitude D600 Notebook Logo
63 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
