Question about Motorola Mobility RAZR V3
Dust under main menu lens?
Is there any way to remove and replace the lens and also seal it to prevent additional dust particles from adhering to the inside of the lens? I am out of warranty, and do not really want to exchange for a reman unit.
    Brigadier General:
  • 7,752 Answers
Yes you can take it to a mobile repair tech and have them do that for you.
Posted on Dec 31, 2007
Lens won't open or retract at certain times batteries are new
If there is a creaking noise when it is opening and closing .. it must be some dust or particles which is preventing the movement of the lens .. It can also be the problem with the circuit itself.
Things to do :
1. try to use air to clean in and around the lens.. mainly withing the attachment contacts.
2.invert the lens facing ground and gently tab from above .. with blowing air in the junctions which will remove the particles within.
3.If the lens had been mishandles and there is a wear in the threads the lens need replacement of the parts involved in its movement.
4.If there is a misplaced lever or parts , it needs servicing ..
Always be very careful with the lens.. the parts are pretty delicate and can harm your unit if wrongly handled.
Feb 17, 2014 | Fujifilm FinePix AX550 Digital Camera
Message says airfow blocked, turns on for about a minute then shuts off
1. Remove the air intake filters on your DLP projector. As explained by InFocus, a manufacturer of LCD and DLP projectors, each DLP model will house the air filters in a different location. However, for most DLP projector products, the filters are accessible by unclipping a simple plastic latch.
2. Wipe the air filters with a small cloth dipped in rubbing alcohol.
3. Blow compressed air into the unit's vents. This will force some internal dust out of the DLP projector, but you may still need to open up the unit for additional dust removal.
4. Unsnap the main cover from your DLP projector. Because DLP projectors need periodic lamp replacement, the main cover is rarely secured with screws or bolts. However, if the DLP projector's cover does not snap off, then you'll want to inspect the unit for possible screws or an alternate release latch.
5. Reach in and remove visible dust globs with a paper towel. Be careful to avoid touching the lens, as fingerprint smudges can diminish DLP projector image quality. If you accidentally smudge the lens while picking out dust blobs, wipe the lens with a dry, lint-free microfiber cloth.
6. Spray compressed air into your DLP projector to remove any lingering dust particles.
7. Close up the projector and reattach the filters.
Sep 26, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
The eyepiece lenses have something on the inside. Can they be removed for cleaning?
  1. Carefully clean your binoculars by firstly removing any dirt or dust from the main body and straps using a soft microfibre cloth. Avoid the lenses at this point using any form of cloth on the lenses before removing all dirt and dust particles first could destroy them.
  1. Gently remove all traces of grit, dirt or dust particles from the lenses using a soft lens brush or canned air specifically designed for the purpose.
  1. Waterproof binoculars can be rinsed gently under a tap but be sure to use on lightly running water, avoid high pressure water as it could damage your binoculars.
  1. Gently remove any remaining marks using lens cleaning tools such as a lens pen or lens cleaning fluid and lens tissue. Do not be tempted to use kitchen towel or anything else lying around that is slightly rough and may scratch the surface of the lens, only use a lens pen, lens tissue or a lens cloth. Gently wipe the lens using a circular motion working from the centre of the lens to the outer edge. NEVER apply lens cleaning fluid directly onto the glass (always apply to the cloth) and always ensure that the lens cleaning fluid you are using is recommended for the type of lens coatings that have been applied to your binoculars (Do not use general household glass cleaning products or products designed to clean computer screens or glasses. Such products could destroy the lens coatings of your binoculars if used).
May 15, 2011 | Tasco 7x50 Waterproof w/Imp. Compass...
How to clean the focusing lens?
First question: where is the dust?
If the dust ist outside the cam: no problem. Try a soft brush and remove bigger particles, then take a thin microfibre cloth and clean the dust film on the lens. Be careful - every sand particle scratches the coating, so use the brush!
If the dust is internal it's more complicated.
May be the dust is on the focussing screen. If you dismout the lens, there is a litte lock on the top inside the cam. Do not open without having special tool. Each fingerprint on this little plastic plane is not removable. It's an extreme sensitive fresnell lens.
Don't try to clean that with cloth or brush. Only airflow is allowed.
If this dosn't help - use the Canon service or replace the focussing screen with a new one (as Example Canon EF-D).
Dec 31, 2010 | Cannon EOS 50D Digital Camera
Dust behind lens
If the dust is inside the lens, then you are unlucky. Canon lenses (except for a select number of the L series lenses) are not dust or weather sealed. So each time you work the zoom mechanism on a inexpensive EF 75-300mm f/4-5.6 III lens, the mechanism is working like a giant billows allowing air (and dust and moisture) to flow through the lens and camera body. Sometimes large dust particles can accumulate on the different lens elements, but it does not have any impact on the quality of the photo
If the dust is creating problem fro your picture get it fixed from service center i will suggest you should not try to open it
Regards
Nov 27, 2009 | Canon PowerShot Pro1 Digital Camera
The lens does not close. I turn in on and off and still nothing.
I'm sorry that the camera is not turning ON. Please make sure that the battery is fully charged and there are no dust particles near the lens which stops retracting. Check if you are able to access the Menu. If yes, then, please Initialize the camera under Main settings 1 Menu. If you are not able to access the menu, you may have to power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 27, 2009 | Sony Cameras
Lens goes in and out, stays out when off and says
I'm sorry that the lens of the camera is not retracting. Please make sure that the battery is fully charged and there are no dust particles near the lens which stops retracting. Check if you are able to access the Menu. If yes, then, please Initialize the camera under Main settings 1 Menu. If you are not able to access the menu, you may have to power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 26, 2009 | Sony Cameras
Lense stuck out and can't take pictures
In all probabilities, the lens barrel must have tilted, preventing the lens from retracting into the barrel. It could also be possible that some dust particles got stuck in between the segments of the lens barrel. Check for these. Try to straighten the barrel without using much force, and try to remove any dust particle that got stuck between the segments.
Jan 14, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Dust Behind Lens on F707
That's odd. I had the 707 (may she rest in God's eternal peace), and never thought that dust could get behind the lens. Do you see the dust when you look through the EVF, or when you look at the lens itself? Either way, one way to test it is to set the camera to the smallest aperture (f/8), infinity focus, and shoot a clear blue sky. Open the picture in your editor program, and see if the dust shows up. That's a technique to use with an SLR to see if the dust inside would affect a picture, so I'm not sure if this will work with the 707.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
550 Problem: Dust collecting inside Viewfinder
I had hoped that a few people would check their cameras and posted replies before I contacted Pentax about my dust problem, but nobody has so far. But it's interesting that someone else posted a message this morning that he has some dust inside the lens of his 550. Anyway, this morning Pentax Canada told me that there should definitely be NO dust inside the viewfinder or the rest of the camera for that matter. Although the Viewfinder is "almost sealed" from the rest of the camera, it is not a total seal - which means to me that if dust can get into the viewfinder, it can get into the rest of the camera's interior - including the lens and imaging chip. They have asked me to bring my camera in so they can remove any dust particles that are inside. Basically, they told me that the only place I should see any dust is inside the lens cover, which is meant only as a protective covering rather than a seal from dust. Even then, they claim that any dust on the outer lens would only enter while the camera is being used. That one I don't buy, as the lens cover is very flimsy and can easily be accidentally spread open while the camera is turned off.
Sep 08, 2005 | Pentax Optio 550 Digital Camera
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
