Question about LG Flatron L1951S 19" LCD Flat Panel Monitor
LG Flatron power save mode
So I moved my computer from one desk to the other, reconnected everything fine (I triple checked) and while the computer boots up fine* the monitor stays off at which point I press the power button and it gives me a message of 'power saving analog mode' and goes black again. I've tried using the cd that came in the packaging but, as I can't see anything its not terribly helpful. This also apparently happened before, but my sister can't remember what she did to fix it.
* I assume, its making all the correct noises
  • ekter Feb 21, 2008
    i've got the same issue. i followed the directions, turning off the computer, then hooking things up and turning everything on. all i get is a power save mode screen. my secy told me i should set the old monitor back up, then remove it and plug in the new one without turning the computer off. she said the computer will then recognize the new equipment. does that make sense? the instructions definately say to turn off the computer first, but then that's not working.
  • 188 Answers
I bet you plugged into the VGA output on your motherboard instead of your video card. I accidentally did this once myself. Look on back of the machine and see if there is more than one possible place to plug the monitor into.
If that's not it let us know and well try to find another fix.
Posted on Dec 31, 2007
Maybe this can help
Control panel>Power Options>Power Schemes Dropdown Menu>Always On
If this doesn't help, you need to try an other monitor on that pc
if second monitor works, you need to reinstall you're monitor software.
if the second monitor fails too, you're graphics card is probably broken.
Posted on May 13, 2008
Stop my lg flatron w2053tq monitor going immediately into power saving mode
How old is your monitor? You may have some bad capacitors. At any rate, you'll have to take the monitor to a Technician for troubleshooting. Good luck.
Feb 28, 2015 | LG Flatron W2053TQ
Flatron W2353 monitor wont turn on
LG W2353 dvi power saving mode
how to fix ?
Dec 22, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
Hi I wonder if you can help me. I have the flatron L1918S monitor and it was working fine yesterday, however today when i turned on the pc, the monitor flashed the green light on and then goes into power...
When after power up the computer press num lock key if num lock led is flash on and off when you press num lock key then your cpu is working fine.But if it stay constant then open cpu cabinet cover then reconnect RAM memory and processor and it's fan pull cmos cell from motherboard for 10 minutes then reconnect it then check.Make sure motherboard is not ground with cabinet. If num lock led is on and off then when you power up the computer press F8 key 5 to 6 times so you can see safe mode and other menu then enter in "Enable vga mode" then go to display property ->settings change screen resolution to 1024*768 then apply and ok. then check. If everything are fine in cpu then your monitor need repairing. Let me know if you need further assistance. Thanks for using FixYa.
Aug 25, 2010 | LG Flatron L1919S LCD Monitor
Lg flatron w1952tq goes into power saving mode on boot computer works fine on other monitor. Running Kubuntu linux.
your LG monitor is bad then if you put another monitor on the computer and your getting video. Just as a last resort, you might want to put the LG monitor on another computer and if it stays in sleep mode then you know for sure at that point, the monitor is bad.
Feb 06, 2010 | LG 22" FLATRON LCD Monitor
My lg flatron model w1934s was working fine but now it will not come out of power saving mode at all. What should I do?
Try turning it off and hold the power switch in for about a 30 seconds. This may help to reset the monitor. Afterwards, try and power it up again.
Oct 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Power saving mode on screen when I turn computer on
if you are using dvi connector, change to vga connector
Jun 23, 2009 | LG 22" FLATRON LCD Monitor
Analog power saving mode?...
I have a LG flatron wide keeps saying Analog power saving mode and than powers off how do I reset this?
May 13, 2009 | LG 22" FLATRON LCD Monitor
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Flatron L1719S
I think your monitor is unstable. Is it showing power saving when you boot your PC? Does it show something when the Windows XP splash appears?
Jun 05, 2007 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1951S 19" LCD Flat Panel Monitor Logo
682 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
